Touchpad problem
Started by Mares, March 28, 2020, 07:06:40 AM
Mares
i got CurrentRanger R3. So far so good. But i have the problem that the double touch is not working really good (Auto Range,BIAS,LPF).
I have to try 10 or 20times to touch both pads if it goes into Auto-Mode for example.
Is there a setup problem? Can a sensitivity change in the software fix the problem? Wrong parts on the board assembled?
Single contact to the touch pads is no problem. Only the simultanious touch.
I hope for help.
I test each individual unit myself, and go through all the combinations, I never saw anything like that or I would change the touch sensitivity in the firmware.
What happens if you just touch one of the pads, then put your finger on the other? Is there a delay before it switches mode? Or it just doesn't work? What if you slightly moist your fingers?
Mares
Mostly it doesn't work.
Take a look in the video.
Ok i see, is this the original firmware?
Mares
Yes it is the original Firmware. I got it on Friday from Welectron. I think its a new batch.
Any Idea?
Can you contact me over email and I will try to help replace the firmware.
[email protected]
davidEnds
#6
Hi! I love my new current ranger but same problem here. Buy from Welectron and R3 version
davidEnds,
Which R3mk is it?
Can you connect just the CR to the USB, open a serial port and send 't', if you have latest firmware that should enable touchpad sensitivity debugging.
davidEnds
R3 Mk4. Ok Ill try it :) Thks
davidEnds
The LPF and BIAS works perfect when the USB is plugged. When I remove it, it doesn't work again
davidEnds
Sorry, it just got back to work by plugging it into the usb and unplugging it again. What would be the explanation? Thanks for your time Felix
Sorry I completely missed the updates.
What output do you get when you type 't' with USB plugged?
See this line for that option, or send '?' for the menu options:  https://github.com/LowPowerLab/CurrentRanger/blob/master/CurrentRanger_R3.ino#L320
davidEnds
The current ranger doesn't show me anything on the
serial monitor. But the touchpad works well again just by connecting it to the pc
You're probably opening the USB port too late.
However regardless of that, if you open the IDE's serial monitor and send a ? followed by ENTER, you should get the MENU shown up.
Ensure it is the CR serial port and not some other serial port.
davidEnds
