Hello everyone.
I'm sorry for a potentially noob question. I've read the safety precautions but still not sure if the setup I want to use is "illegal"
I want to use CR in the testbench which would program the MCU over JTAG and then measure sleep current. I want to transfer data over USB, noise is not a problem as I measure average over a long period of time. DUT is powered by 3V battery, there's no power supplied by the debugger (only data+ground), however I have to connect debugger's GND to DUT's "-" terminal, otherwise debugger would have no reference. Here is a quick sketch of the setup. As far as I understood from the manual, this setup is NOT safe.
It is NOT OK...to measure a DUT that is mains/earth powered/connected, while USB is also connected. This is passing current through the CR, from the input terminal, to the USB earth/ground, and will completely damage the CR
But looking at the CurrentRanger schematic, I can't understand why (where the short circuit would be).
If it IS indeed dangerous, would USB isolator help? Should I use 2 of them on both USB connections (to CR and Programmer)?
Thanks a lot.
