I have a CR stuck in bootloader mode, I tried to program it using the Arduino IDE but keep getting this error:
Sketch uses 89276 bytes (35%) of program storage space. Maximum is 253952 bytes.
Forcing reset using 1200bps open/close on port COM8
PORTS {COM8, } / {COM8, } => {}
Uploading using selected port: COM8
C:\Users\saj-2\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM8 -U true -i -e -w -v C:\Users\saj-2\AppData\Local\Temp\arduino_build_927021/Current_Ranger.ino.bin -R
No device found on COM8
Set binary mode
An error occurred while uploading the sketch
How can I take it out of bootloader mode or just update the firmware?
Help please
You seem to report that it is stuck in bootloader mode, how did that happen?
Anyway you have to select the appropriate COM port when the unit switches to bootloader, although that should be done automatically by the IDE.
The guide and steps for re-programming the unit are on this page, please follow this guide:
https://lowpowerlab.com/guide/currentranger/programming-firmware-updates/
