I'm a student and trying to use the CR for an internship and I was wondering if I could use the CR and HC-06 via Windows.
I read this on the Bluetooth page:
The HC-06 Bluetooth module is recommended since it’s well supported and easy to use. It usually comes set to 19200/115200 baud. The default CurrentRanger firmware serial header baud is set to 230400, so you need to match this baud in the HC-06 module using the AT command set (by issuing the AT+BAUD9 command), see this link for more details.
And somewhere on the internet I found this:
Note: Windows cannot use baud rates above 115200. If you are using Windows and you accidentally set the baud rate higher than 115200 you’re screwed!
The HC-06 I currently have has the standard 9600 baud.
Do people use Python? Or does it just work on Windows?
Or can you change the Baudrate in the Firmware easily?
I'm a bit hesistant to upgrade the baud right now because of the warning message.
Thanks in advance,
Floris
