help with the schematic
Started by bretskee, March 20, 2020, 08:04:26 PM
bretskee
as in one of the other posts, I too have stupidly damaged my unit. In diagnosing the issue, I looked at the schematic and am wondering how part of it is intended to work. The section is attached. I understand of course how the mosfets introduce the shunt resistors for uA and nA, but I do not understand the logic of the mA circuit and how the RDSon of its mosfet is not significant in the path. Could you explain the idea behind the bypass mosfets also please. The NMA tag is a mystery as it does not appear anywhere else on the circuit.
A brief explanation would be helpful. Thanks
Without going into very detailed detail, that circuit is part of the switching and biasing logic.
But to get to the botttom of your problem - you're in need to fix your CR correct? Maybe I can help more with that.
bretskee
OK, i have found my issue with a blown mosfet and repaired it by using one from the uA switching circuit. The rest of your answer is not very helpful.
Did you buy your CR from LPL or from WELECTRON?
