Software support => Coding questions => Topic started by: [email protected] on December 07, 2019, 11:12:01 PM
Title: TxRxBlinky Sketch in RFM69 Examples
Post by: [email protected] on December 07, 2019, 11:12:01 PM
In this Sketch. (Examples>RFM69_low_Power > TxRxBlinky ). I have two questions:
1) What is Rx_TOGGLE_pin  7;  used for?
    I don't see this pin on the ATMEL 328 connected to the RFM69 at all.
    Should this be Pin 10  (D10) that is  connected to RFM69 SEL input?
2) What are  LED_GREEN  4; and LED_RED  5; Used for?
  Was I supposed to Add these two LEDS to these pins, or are they already on the Moteino board (don't think so)
Thank you
  Newbie John
Title: Re: TxRxBlinky Sketch in RFM69 Examples
Post by: Felix on December 08, 2019, 11:53:09 AM
Hi John,
I tried to comment this sketch pretty heavily, but probably didn't think about the absolute beginner, my apologies.
RX_TOGGLE_PIN is just a pin that is toggled depending on the state, you can ignore it, not even sure what I had in mind for this pin.
For the additional RED/GREEN LEDs, if you take a look at the code, you will find this section:
    if(LEDSTATE==LOW)
      LEDSTATE=HIGH;
      digitalWrite(LED_GREEN, HIGH);
      digitalWrite(LED_RED, LOW);
    else
      LEDSTATE=LOW;
      digitalWrite(LED_GREEN, LOW);
      digitalWrite(LED_RED, HIGH);
As you can see, the LED_GREEN and LED_RED are toggled (only 1 is ON at 1 time) based on the state of the LEDSTATE variable, which in turn is toggled by the messaging between the 2 nodes loaded with this sketch.
It's a very very simple sketch illustrating how to ping pong a message between 2 nodes. This sketch is loaded on BOTH ends, just configure settings on each, give them unique IDs etc.
D10 (aka radio SPI CS) on Moteino is always used by the radio/SPI, it's hardwired to it.
