Hello
I want to use two RFM69HCW transceivers to establish a radio connection between two Arduino Nano Every ATMEGA4809. I have find this example on the Internet.
https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide?_ga=1.266083855.1455005990.1484889845
I connected the Arduino Nano Every as in the example with a logic level converter and also without a converter.
Unfortunately, I didn't manage to connect the two boards. I also searched the internet for a long time for further examples or help. But here I also found no further information.
Have someone an idea how I can establish a radio connection with the Arduino Nano Every with an RFM69HCW module?
Thanks in advance.
How to make Arduino Nano work with RFM69. This type of thing has only been asked about 7 million times on this forum.
The EVERY is a new board I am not familiar with. You have to check the serial CS and Interrupt pins, pass them in through the RFM69 constructor if they are different.
Make good solid connections. It's a 5V board so yes you need logic buffering since the RF chip is 3.3V.
Good luck and may the force of self-torture be with you, doing what otherwise would work out of box on a humble Moteino.
