sendwithretry buffer size
Started by therrien, May 12, 2019, 09:02:14 AM
therrien
What is the right value for the buffer size when I send "ACK_TEST" with sendwithretry.  8 ou 9.
9 to include '\0'
Quote from: therrien on May 12, 2019, 09:02:14 AM
9 to include '\0'
It depends on how you're going to use it at the receiving end.  If ALL you want to do is send the printable characters, the correct length would be 8.  However, if you want to send a null terminated string, length should = 9 so the termination byte will be included in the packet.
sendWithRetry doesn't care about the content, it only wants to know how many bytes to send over the air...
therrien
