RFM69 strange behaver
Started by enrique34, November 24, 2021, 03:35:27 PM
enrique34
Hello everyone;
i'm trying to find out a strange behaver of my RFM69HW module.
i've two boards that are Slave and Master. Basicly Master board sends a command to Slave board to get temperature value.
the code of  the Master side:
for(uint8_t i=0;i<3;i++)  //try to send 3 times
 sending_error=1;
 try_sending_count++;
 RFM69_send(slave_id,"get",3,false); //send the command data to get temperature value from Slave
	for(uint16_t j=0;j<100;j++)     // wait 100ms the data coming from slave
	    delay_ms(1);
	    if(receiveDone()==1)
	      sending_error=0;
	      data_process();
	      goto next;
next:
the code of the slave side:
  RFM69_send(master_id,temp,1,false); //send the temp value to Master
  blink_led();
when i run the two side Master sends requesting to Slave every 1000ms
BUT Slave can not get every commands coming from Master even if they are close each other.
when i change both side such this:
MASTER :
 delay_ms(500);
SLAVE :
  blink_led();
Slave can get all data coming from Master and i can see every requesing via blinking led.
in additionally when i change such that :
MASTER :
 sending_error=1;
	    delay_ms(1);
	      sending_error=0;
	      data_process();
	      goto next;
next:
SLAVE :
  blink_led();
in this situation Slave can send successfully.
BUT it is a trick is not a technic.
i think that if master or slave are in RxMode after TxMode or TxMode after RxMode, they can't do next mode successfully.
i hope what i want to tell you guys...
Thanks.
