NODE MCU ESP2866 - Will Not Complie
Started by G00NOLA, May 25, 2019, 02:55:57 AM
G00NOLA
I am new to the RFM69 and I am trying to use it with a NODE MCU ESP8266, but I cannot get it to compile.  Am I missing a declaration or something?
#include <RFM69.h>
#include <SPIFlash.h>
#include <SPI.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
//#include <LowPower.h>
SoftwareSerial ss(12, 13);
TinyGPSPlus gps;  //Creates a GPS object
#define IS_RFM69HW_HCW;
#define NETWORKID = 10;
#define MYNODEID = 1;
#define TONODEID = 2;
#define FREQUENCY RF69_915MHZ;
#define ENCRYPT true;
#define ENCRYPTKEY "Track";
#define USEACK true;
RFM69 radio;
double setLat;  //Variable for storing the set point latitude
double setLon;  //Variable for storing the set point longitude
double compLat;  //Variable for storing the compared latitude
double compLon;  //Variable for storing the compared longitude
const int pot = 0;  //The potientiometer is on Analof Pin 0
int D;  //Variable for stoeing distance
int setD;
int potVal;  //Variable doe storing the potentiometer reading
int condition = 0;
int lastCondition = 0;
int valD;
void setup() {
Serial.begin(9600);
ss.begin(9600);
radio.initialize(FREQUENCY, MYNODEID, NETWOEKID);
radio.setHighPower();
if(ENCRYPT)
  radio.encrypt(ENCRYPTKEY);
void loop() {
if (setD == 0)
  valD=analogRead(pot);
  setD=map(valD, 4, 1024, 10, 90);
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
     if (gps.location.isValid())
      setLat=gps.location.lat();
      setLon=gps.location.lng();
      condition = 1;
      radio.sendWithRetry(TONODEID, &condition, 1);
        compLat=gps.location.lat();
        compLon=gps.location.lng();
        D=gps.distanceBetween(compLat, compLon, setLat, setLon);  //Calculate delta distance
        if (setD <= D)
          condition = 3;
        else
          condition = 2;
        Serial.flush();
if (lastCondition != condition)
lastCondition = condition;
Before adding the RFM69 library, have you gotten anything to compile for your ESP8266?
What error messages did you get when you tried to compile?
A quick look at your code I found several errors:
// BAD defines: (don't use equals sign or semicolon)
#define ENCRYPTKEY "Track";   // encrypt key must be exactly 16 bytes long
// MISSPELLED NETWORKID
G00NOLA
Thank you, TomWS I still need to do some testing but at least is has complied.
