Feedback wanted on using Atom and PlatformIO for Moteino projects
Started by Sean, August 26, 2018, 11:28:22 AM
Sean
The Arduino IDE has been a great to get started with programming Moteino. However, now that I'm building libraries of code for reuse I'm finding it a bit lacking compared to IDEs I've used (for C++ programming) in the past.
I'm now experimenting with using Atom+Platformio (based on setting from Robin Reiter's YouTube video) in place of Arduino IDE.
Does anyone have feedback or recommendations on using Atom+Platformio for Moteino projects?
Sean
I use Atom and Platformio exclusively for Arduino projects - for both AVR & Expressif processors.  I like the environment much better than Arduino IDE and I no longer get whiplash from trying to keep up with the IDE du jour.
However, from what I've seen, it appears that the Debugger support is better with the VSCode framework rather than Atom.  I don't use the Debugger (yet), but probably will when I start including the Arm processors in the mix.
