Char[] issues - variable scope or something else? [SOLVED]
Started by gregcope, February 05, 2019, 03:21:06 AM
gregcope
Hi All,
Tldr; dtostrf(orgLon, 9,6, lonStr); does not appear to work!?!?!?  The lonStr is not correct when sprintf'ed in another function.
Writing what effectively is a GPS/GSM tracker.  I want to send a data string via HTTP over GSM.  This is using the Ardunio IDE, TinyGPS++ for nmea parsing.  The GPS object is a wrapper to TinyGPS++ with methods to control hardware etc...
I use global variables for some shared data.  The main() and associated functions deal mainly with state.  All the hardware and some other things are created as Objects and their variables are hence hidden.
There is a function to update GPS lat/lon location.
Another function to create the char[] message.
In top of the .ino file I have;
double orgLat = 0; // Last recorded Lat
double orgLon = 0; // Last recorded lon
double distance = 10000; // distance moved (default)
char latStr[10]; // lat string
char lonStr[10]; // lon string
void checkLocation(void) {
  // update location
  gps.getUpdatedFix(UPDATE_GPS_FIX_TIMEOUT_MSECS, UPDATE_GPS_NUMBER_OF_FIXES);
  distance = gps.distanceMoved(orgLat, orgLon);
  // save present location
  orgLat = gps.getLat();
  orgLon = gps.getLon();
  dtostrf(orgLat, 9,6, latStr);  //first number is length, last is numbers after decimal
  dtostrf(distance, 9,2, distanceStr);
  DEBUG("distance: ");
  Serial.println(distanceStr);
If it print the latStr and lonStr in this function they are correct.
void sendMessage(void) {
  //Get a dateTime String
  sprintf(dateTimeStr, gps.getdateTime());
  //Put the message together
  sprintf(messageStr, "'%s,%sv,%sv,%sc,%s,%s,%s,%dm'", dateTimeStr, lipoStr, vccStr, tempStr, bilgeStr, latStr, lonStr, distanceStr);
  DEBUG("Message is: ");
  DEBUGln(messageStr);
If I print the latStr and lonStr in this function they are incorrect.
However in the messageStr gets populated with garbage.  latStr looks like a Latitude, but is not the most recent, the lonStr is only 3 digits long.  I am near London so Lon is negative - something like -0.45453377
Will post some actual code output later as on the train to work!
gregcope
Here is an example output;
checkLocation function output
getUpdatedFix: GPS Location: 51.014015,-0.439823, Date/Time: 2019-2-05T18:43:00.00Z, -----lat is:  52.015015lon is:  -0.439823
sendMessage function output
-----lat is:  52.015015lon is: .75
Message is: '20190205T18:43:00Z,3.3v,0.1v,20.5c,BILGE:OK, 52.015015,.75,    31.75m'
Let's see... you don't include the declaration for distancestr so we have no idea how the dtostrf() function will behave.
Your sprintf format string for the output of distancestr is "%dm" which is probably not what you want.
And you're sure cutting it close declaring the character buffers to be 10 bytes long even with a size 9 format...
But the really good news is that your bilge is OK!
gregcope
Okay ... few issues.  Maybe I should have added I am a newbie at this.
char bilgeStr[12];
char latStr[30]; // lat string
char lonStr[30]; // lon string
char distanceStr[6];
distanceStr is fine (I think..)
Changed the sprintf to %s
Changed char buffers to 30.
Still no joy !?!?
Yes, Bilge is OK!  Would be worried it not.
gregcope
Okay... 6 is too small so changed;
char distanceStr[30];
gregcope
Thanks TomWS...
Was too short and probably over writing the previous declared variable (lonStr) ... which caused the garbage.
Now that's fixed.
You will be pleased to know bilge is still Okay.  And the temp in the house is a nice 20.5C
Quote from: gregcope on February 05, 2019, 03:07:44 PM
Your statement:
requires distanceStr to be at least 10 bytes long (9 for characters, 1 for string termination).
gregcope
Yep. Stupid mistake on my part.
Is there a convention on buffer Char arrays?  Just make them huge? Ie 3x bigger and not bother with the RAM impact?
Thanks for your help.
Quote from: gregcope on February 06, 2019, 01:42:23 PM
Simple enough to do, everyone's done it...
It's easy enough to make them 'right' sized.   Theoretically 10 characters were just enough for the format specification you had.  I tend to add a bit more because ya never know when you're going to change the format and mess up the memory.  The tricky ones are things like serial input buffers from command lines, etc.  You always think you have enough and then something blows up.  These processors are too memory anemic to waste space, but it is important to right-size.
