Can buy this nice NES Case at Amazon for $20. (http://amzn.to/2q3OHth)
It does have a hole for a LED but the power and reset I guess could cut them out to use them like a power and reset with the ATX power?
If so how can wire up 2 switches one for power and one for reset. Can you do that with the ATX power?
-Raymond Day
All wiring is explained in the guide (https://lowpowerlab.com/guide/atxraspi/assembly-install/).
Here's the wiring for [latching power] + [reset] buttons:
(https://lowpowerlab.com/wp-content/uploads/2016/09/ATXRaspi_GPIO_latching_with_reset2.png)
That's good they have this option! Thanks for posting it.
The latching option 10K resistor has now been added to the board and you only need to solder a solder bridge on the bottom of the PCB (starting with R2.8).
For the reset you can also do that same as in the photo.
