M0 OTA Programming
Started by mah115, August 21, 2019, 05:42:43 AM
mah115
I actually had a question, is there a reason you set the frequency to 917MHz instead of 915MHz in the example?  I was just wondering if there's something that needs to be tuned.
Good to hear you also have it working.
The 917mhz is no particular reason, just had some other things running at 916 and wanted to isolate the OTA as much as possible, should have probably left it at 916 for the commit to avoid confusing people.
sparky
Here I thought that both sender and receiver had to be set on the same freq.
sparky,
They do. They just both shift frequencies during OTA.
mah115 was talking about the hardcoded base frequency, which in the OTA examples changed to 917. I'll change it back  ::)
