Remote temp. transmitter - which sensor is this?
Started by Lukapple, February 16, 2019, 06:32:39 AM
Quote from: Lukapple on March 05, 2019, 03:56:48 AM
Any idea how to replicate that kind of signal with Moteino(RF69HW)?
I've done it where I didn't need to keep switching back and forth between OOK and Moteino network.  If you only want the OOK function, I can see what I have.  The code may be too 'married' to another type of device, but the OOK transmitter might be useful. I used Kobuki's code as a base (https://lowpowerlab.com/forum/moteino/new-ook-library-for-moteino/)
Lukapple
It would be great, if you can share the OOK function. Thanks!
RoSchmi
Hello Lukapple,
I had a look on my code how to retrieve the temperatur in Celsius and Fahrenheit from the received bit stream.
So there is no need to reinvent the wheel.
The code is in C#.
// retrieve the measured temperature as an int from the received '0' and '1' in the char array 'outArray'
int gotValue = 0;
int shiftValue = 1;
for (int i = 0 ; i < valueEndPos - valueStartPos + 1; i++ )
      if (outArray[valueEndPos - i] == '1')
              gotValue += (shiftValue << i);
      else
             if (outArray[valueEndPos - i] != '0')
                   gotValue = 9999;                  // gotValue = 9999 if there is at least one ? in the array
                   break;
// Some calculations to transform the measured values which are valid for
// the range from -50°C to +70°C in a form that can be easily displayed
// I'm sure there are more elegant methods to do this task
//Here the int e.measuredValue holds the temperature (gotValue) from the code above
                int measuredValue = e.measuredValue / 2;   // remove last digit, then one bit = 0.1 degree Celcius
                measuredValue = measuredValue & 4095;      // new remove leading 1 s
                //if ((3595 < measuredValue) && (measuredValue < 4096))  // Negative readings are valid from -0.1 to -50 degree Celsius
                if ((3700 < measuredValue) && (measuredValue < 4096))  // Negative readings are valid from -0.1 to -39 degree Celsius
                    measuredValue = 4096 - measuredValue;
                    degreeCelsiusString = "-";
                    degreeCelsiusSign = false;     // sign is "-"
                    measuredValuePlus50 = 500 - measuredValue; // // to have only positive values we add 50 degree Celsius
                }                                                 // then -50°C = 0, 0°C = 50, 70°C = 120
                else                                              // now it is easy to compare with certain thresholds
                    if ((measuredValue >= 0) && (measuredValue < 701)) // Positive readings are valid from 0 to +70 degree Celsius
                        degreeCelsiusString = "+";
                        degreeCelsiusSign = true;   // sign is "+"
                        measuredValuePlus50 = measuredValue + 500;  // add eqiv. 50 °C
                    else
                        degreeCelsiusString = "???";
                if (degreeCelsiusString != "???")
                    // calculate celsius value
                    //decimalValue = ((double)measuredValue / 10);
                    decimalValue = degreeCelsiusSign ? (double)measuredValue / 10 : -(double)measuredValue / 10;
                    decimalValuePlus50 = ((double)measuredValuePlus50 / 10);  // by adding 50 degree Celsius the valid range -50 - + 70
                    // is now 0 - 120
                    degreeCelsiusString = decimalValue.ToString("f1") + " °C";
                    // calculate fahrenheit from celsius
                    fahrenheitValue = decimalValue * 1.8;
                    if (degreeCelsiusSign == false)
                    { fahrenheitValue = fahrenheitValue * -1; }
                    fahrenheitValue += 32;
                    if (fahrenheitValue >= 0)
                        degreeFahrenheitString = "+" + fahrenheitValue.ToString("f1") + " °F";
                    else
                        degreeFahrenheitString = fahrenheitValue.ToString("f1") + " °F";
                else
                    decimalValue = InValidValue;
                outString = outString + bitString.Substring(0, 9) + " " + bitString.Substring(9, 15)
                            + " " + bitString.Substring(24, 5) + "  Measured Value: "
                            + degreeCelsiusString + " (+50 = " + decimalValuePlus50.ToString("f1") + ") "
                            + degreeFahrenheitString + "  " + "  Time: "
                            + e.ReadTime.Hour + ":" + e.ReadTime.Minute + ":" + e.ReadTime.Second
                            + "  Repetitions needed: " + e.repCount
                            + "  Failed Bit-Count: " + e.failedBitsCount
                            + "  Eliminated Noise Spikes: " + e.eliminatedSpikesCount;
                _Print_Debug(outString + "\r\n");
Lukapple
Actually I already have conversion functions from my other project (temperature sensor DS18B20).  Thanks for the code anyway!
What I really need is example function to reproduce signal with Moteino(RF69HW)? @TomWS can you share a demo sketch please?
Lukapple
I've managed to successfully replicate the signal!
Now I can send temperature from my moteino sensors (ch1=outdoor, ch2=pool water temp.) to the wall clock ;D
Thanks for help guys!
Lukapple, that's awesome!
Any chance you can post your code/findings here for posterity?
Lukapple
#21
Sure, here is the example sketch, that sends 60.0C signal to channel 1.
It sends following signal 5 times (original temperature transmitter sends package 5x, so I reproduced that):
010101011000100000100101100000010101
Please note that this is just a test sketch and not final production code.  :)
Necessary modifications to the Moteino: connect DIO2 to D3 (INT1) pin (DIO2 is the OOK data pin)
