Felix,
I've now run into problems where your version of the library seems to cause issues. I'm using both RH_SERIAL to communicate between two Arduinos, one of which is a moteino with the lora radio. If I use your lib, lora works but I see quirks on the serial comms. If I use Radiohead library proper, I don't seem to have the serial issues but the lora doesn't work. To work through the process of elimination, it would help if you could point me in the right direction to find the tweaks you made to the library so I can integrate them into the current lib. I believe there are now four revisions difference and I suspect therefore there will be a large number of deltas that have nothing to do with the moteino changes you needed to make.
Forgive me if this is a silly question. I'm not sure how to perform a diff on the entire lib so happy to take your advice, even just knowing which files were changed would be great.
btw I love the moteino with lora and have ordered a bunch. Thank you for these. I've built a very basic lora/ethernet gateway using a moteino. However, I have one complicated little beast of a sodaq arduino that runs a remote livestock watering pump (must be rock solid) and rather than port it to moteino and go through bug fix (thirsty cows or worse), I'm bolting a moteino onto it and the two talk with RH_SERIAL. This should let me connect that pump controller relatively unchanged through the lora gateway to cellular and the "cloud". Sounds kludgy but I want to avoid changes to the pump control arduino.
