LowPowerLab Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Blog
Shop
Help
Search
Login
Register
LowPowerLab Forum
Hardware support
RF - Range - Antennas - RFM69 library
RSSI difference same hardware
Print
Pages: [
1
Author
Topic: RSSI difference same hardware (Read 923 times)
Junges
NewMember
on:
May 17, 2018, 06:32:29 AM »
I have the following questons:
1)Should i see difference in rssi from a bunch of different rfm69hw radios with exactly same firmware and hardware? The difference is something around -20 in some cases without obstacles at same position and same spatial orientation of the device.
Logged
LukaQ
Sr. Member
Country:
Re: RSSI difference same hardware
Reply #1 on:
May 17, 2018, 09:55:25 AM »
depends... are they transmitting at the same time? Do you have the same antennas, same orientation? Do you have them too close to each other?
20dB is a lot, so no, you shouldn't see that much
Logged
http://www.classdaudio.eu
https://github.com/LukaGitH/Moteino
Junges
NewMember
Reply #2 on:
June 11, 2018, 01:41:17 PM »
Exactly same hardware, firmware, antenna and orientation and enclosure.
Is it possible two brand new rfm69hw transmit a different power even being configured with same firmware? (Same setpower level for instance)
Logged
LukaQ
Sr. Member
Country:
Reply #3 on:
June 11, 2018, 02:57:30 PM »
I don't think that is possible, no.
Do you have both transmitters on at the same time or just one at a time?
Logged
Print
Pages: [
1
LowPowerLab Forum
Hardware support
