Author Topic: Coot's Raspberry Pi Gateway Trek (running on JDK 1.8.0-b129)  (Read 2398 times)
cootcraig
    • Coot's Blog
« on: March 07, 2014, 12:59:42 AM »
Nothing useful yet, but the demo is promising so far.  Here is
where I'm keeping my proof of concept project.  There is a
readme with some notes.
https://github.com/CootCraig/reel_https_auth_websock
This shows the Java and JRuby versions used.
$ jruby -v
jruby 1.7.11 (1.9.3p392) 2014-02-24 86339bb on Java HotSpot(TM) Client VM 1.8.0-b129 +indy [linux-arm]
As of now, https://1.2.3.4:4430/ just says hello.  I'm easily excited though.
cootcraig
    • Coot's Blog
Re: Coot's Raspberry Pi Gateway Trek - Pi setup
« Reply #1 on: March 07, 2014, 01:05:56 AM »
Notes on setting up the Raspberry Pi are on my blog here.
http://www.coot.net/blog/2014/03/raspbian-netinst/
cootcraig
    • Coot's Blog
Re: Coot's Raspberry Pi Gateway Trek (running on JDK 1.8.0-b129)
« Reply #2 on: March 08, 2014, 10:39:49 AM »
$ jruby -v
I just kicked off on Rpi a version with:
* https
* cookie based authentication
* login page presented if cookie auth fails
* server time updated on websocket.
I will let this run a while and check cpu and memory usage.
Next up will be interacting with a directly connected Arduino.
cootcraig
    • Coot's Blog
« Reply #3 on: March 08, 2014, 10:46:59 AM »
I want to add these functions to the non Arduino version.
* Have the HTTP server start at boot time.
* Output the server times on both websockets and a zeromq pub socket.
cootcraig
    • Coot's Blog
Ready to order some Moteinos!
« Reply #4 on: March 12, 2014, 01:15:41 PM »
I have my proof of concept working so I will order some Moteinos
and expand this out to a remote Moteino.
Highlights
* HTTPS server requires user/password login. login stored in cookie
* Arduino sends messages to Serial on a timer
* Web page shows Arduino Serial messages live with a websocket
* Web page can send message to Arduino Serial that changes the Arduino output
* Using udev rule to create ttyUSB link /dev/Diavolino
* Using Socat to wrap /dev/Diavolino in TCP
HTTPS gateway using Java here:
https://github.com/CootCraig/pi_arduino_io_1
Arduino sketch is here:
https://github.com/CootCraig/pi_arduino_io_1/blob/master/sketchbook/timer_echo/timer_echo.ino
labusr
« Reply #5 on: March 17, 2014, 12:27:05 PM »
Hi Craig,
How's the project going?  I'm trying to do a similar thing, following along with Felix's Raspberry Pi gateway example.  I kinda got stuck with the socket.io.  I'm not much of a linux user, basically just copy and pasting what I see with some goggling when I run into trouble.
Is it bad form to ask for SD card images?  I'm looking for a RPi + Arduino solution for wireless sensor network, but it's been slow going trying to get the socket.io and all that other webserver stuff going.
