If you would like to use your ISP's email server instead of Gmail or the like here is how to set up Nodemailer to do that.
In settings.js modify the exports.credentials:
exports.credentials = {
emailservice : 'gmail', // Default is gmail, see nodemailer reference for other clients -
https://github.com/andris9/Nodemailer emailhost : 'ISP_Email_Server_Address', // Your ISP's email server address
port : 'ISP_Email_Server_Port_Numer', // Your ISP's email server port
email : 'ISP_Email_Address', // Put your ISP email address here
emailpass : 'ISP_Email_Password', // Put your ISP email password or app access code here
emailAlertsTo : 'ISP_Email_Address', // Put your alert/notification email here (can be the same as above)
smsAlertsTo : 'SMS', // if you want SMS notifications, fill this in with your phone number (it's your cell#, domain differs for each carrier, ex: 5551234567@vtext.com for verizon)
In gateway.js modify the following from:
var transporter = nodemailer.createTransport({
service: settings.credentials.emailservice, //"gmail" is preconfigured by nodemailer, but you can setup any other email client supported by nodemailer
auth: {
user: settings.credentials.email,
pass: settings.credentials.emailpass,
To the following:
var smtpTransport = require('nodemailer-smtp-transport');
var transporter = nodemailer.createTransport(smtpTransport({
host: settings.credentials.emailhost,
port: settings.credentials.port,
auth: {
