Gateway nodes not showing - gateway.db not logging [solved]
Started by EnMon, January 23, 2017, 07:02:59 PM
EnMon
Thank you so much Felix and Sparky,
I had difficulty matching the metrics to my data but I have been able to fix it.
My Nodes are showing on the app now. :D :D
EnMon
Ofcourse!! :D
Thank you so much.
sparky
Sweet, I haven't had any luck upgrading to 8.8, I might try to start from scratch.  Unless Felix comes out with a pre-built image..!!   8)
Quote from: sparky on January 24, 2017, 04:53:24 PM
Actually I want to get away from a prebuilt image and would rather maintain a script.
The setup script actually works very well and it's fast, gives you a Gateway-Pi in no time, probably less time than downloading a 1GB image.
sparky
I'll have to try again, maybe from a fresh raspbian install??.  I was getting an error stating something about not able to find nconf module
Get latest raspbian, then follow instructions on the gateway setup page.
sparky
Sorry to say, still no luck
When connecting thru browser all I get is waiting for socket connection.
Connecting to Pi thru WinSCP I was able to get log;
[01-25-17_12:13:13.838] [INFO]  LOADING USER METRICS...
[01-25-17_12:13:13.872] [INFO]  LOADING USER METRICS MODULE [_example.js]
/home/pi/gateway/gateway.js:55
  console.error(error.message);
TypeError: Cannot read property 'message' of undefined
    at SerialPort.serialCloseHandler (/home/pi/gateway/gateway.js:55:22)
    at emitNone (events.js:67:13)
    at SerialPort.emit (events.js:166:7)
    at SerialPortFactory.SerialPort.disconnected (/home/pi/gateway/node_modules/serialport/serialport.js:438:10)
    at /home/pi/gateway/node_modules/serialport/serialport.js:236:18
[01-25-17_07:22:50.756] [INFO]  LOADING USER METRICS...
[01-25-17_07:22:50.798] [INFO]  LOADING USER METRICS MODULE [_example.js]
[01-25-17_07:22:50.891] [ERROR] Cannot open /dev/ttyAMA0
[01-25-17_07:23:14.646] [INFO]  LOADING USER METRICS...
[01-25-17_07:23:14.680] [INFO]  LOADING USER METRICS MODULE [_example.js]
[01-25-17_07:23:14.776] [ERROR] Cannot open /dev/ttyAMA0
[01-25-17_07:39:09.383] [INFO]  LOADING USER METRICS...
[01-25-17_07:39:09.417] [INFO]  LOADING USER METRICS MODULE [_example.js]
[01-25-17_07:47:44.832] [INFO]  LOADING USER METRICS...
[01-25-17_07:47:44.868] [INFO]  LOADING USER METRICS MODULE [_example.js]
[01-25-17_07:51:20.438] [INFO]  LOADING USER METRICS...
[01-25-17_07:51:20.474] [INFO]  LOADING USER METRICS MODULE [_example.js]
[01-25-17_07:55:36.160] [INFO]  LOADING USER METRICS...
[01-25-17_07:55:36.196] [INFO]  LOADING USER METRICS MODULE [_example.js]
[01-25-17_08:07:37.578] [INFO]  LOADING USER METRICS...
[01-25-17_08:07:37.611] [INFO]  LOADING USER METRICS MODULE [_example.js]
Looks like your serial connection cannot be opened or something related to the serial.
What's the serial port you use? Did you verify valid data is coming through (or at least a valid connection) via minicom?
sparky
Using /dev/ttyUSB0
Have not used minicom
Reloading everything this morning but now it appears possibly something wrong with the link to gatewaysetup.sh??
sparky
The following error;
was prior to me changing it to USB0
Quote from: sparky on January 26, 2017, 08:04:49 AM
Using /dev/ttyUSB0
The setup guide points to this script, hasn't changed at all, is this what you're using?
sparky
Yes, that's the one I'm using Felix.  I was finally able to download the script..  but with the same, no success, results
Others use the same script and have no issues. That message is indicative of the serial port not being able to open.
You have to ensure the Pi does not lock it up if its the GPIO serial.
Otherwise if its /dev/ttyUSB0 it should just work once you set it in settings and restart the gateway app.
sparky
Felix, I'm not blaming your script, just stating my issues.  Thanks
