Graph for one metric not being shown anymore past some date
Started by LukaQ, October 23, 2017, 02:49:25 PM
Quote from: LukaQ on October 25, 2017, 12:33:07 PM
maybe you can implement something to check if last point is 9 bytes long and is not null or something like that, if possible
That's possible. But a greater question is why and how did that get corrupt record get there. Just looking at bad data is not a lead. Do you have a suggestion what to do with that data?
The logutil code checks for the timestamp, it will not insert a NULL at the end of the file.
I see you look at 9 bytes per line, correct? Then how is your last record only 7 bytes? The file should always have a multiple of 9 bytes length.
Anyway isn't this the exact same problem you had before? I recall combing through your data bin file before, finding nulls.
Is anyone else having this data problem? Certainly not aware of it, but if someone does please speak up.
LukaQ
Quote from: Felix on October 25, 2017, 01:20:41 PM
reboot possible, if not that, power outage... something that would interrupt writing
Quote from: Felix on October 25, 2017, 01:20:41 PMDo you have a suggestion what to do with that data?
I guess delete it, partial data has no place to be in database anyway.
Quote from: Felix on October 25, 2017, 01:20:41 PMThe logutil code checks for the timestamp, it will not insert a NULL at the end of the file.
Ok, that's good, one less possible problem
Quote from: Felix on October 25, 2017, 01:20:41 PMI see you look at 9 bytes per line, correct? Then how is your last record only 7 bytes? The file should always have a multiple of 9 bytes length.
Correct. My only guess would be power loss or reboot just at that time, when file was in writing, do you think that is possible?
Quote from: Felix on October 25, 2017, 01:20:41 PMAnyway isn't this the exact same problem you had before? I recall combing through your data bin file before, finding nulls.
I would say no, since value was ok, but date was I think 1/1/1970 or something like that. At that point I didn't know how to check .bin file.
That data point should be still somewhere, I will find it in a day or two, to see what was going on there.
An exception did happen, that much is clear, just no detail on it.
Seems like nulls/partial data was written.
0 for the timestamp is the unix epoch which is Jan/1/1970. But that has no place at the end of a file.
Another thing I could do is a check on extraction. But if the file has wrong number of bytes then everything is broken, the logutil assumes the records are sequential and 9 bytes each, that's crucial.
There is an UPTIME indicator in the UI which should tell you if the system restarted recently, after a power outage for instance.
A reboot would not interrupt writing of a 9 byte record, that I am pretty sure of, it's an atomic operation. A corrupt SD card on the other hand is much more likely to cause that. And having seen this (only) from you before I think I would bet my money on that. It almost smells like it based on all I'm seeing. When the gateway starts there is a lot of startup logging which I don't see in your case, it's basically impossible.
LukaQ
ok, so for time being, let's not do something and I'll keep my eye on things. I did fix just now all other bin files, that had 9 bytes of 0 here and there. Now the graphs are perfect, from end of february to today and I must say, this is one of the best logging tools
Great, thanks :)
Like I said, the logger can be improved by more checking of bad data.
BUT what I don't think will help is if partial data is written. For that scenario only some automatic data check/fixing could help, maybe some algorithm that checks if the file is a multiple of 9bytes, if not look for bad records, but that is going to be complex - how do you decide where bad data is, establish patterns of data.
I should note here that there is already a check in logutil.js if the bin file is multiple of 9 each time before posting a new datapoint:
if (logsize % 9 > 0) throw 'File ' + filename +' is not multiple of 9bytes, post aborted';
So I would expect to see that exception in your sys.log if the bin files were corrupted in any way. But it doesnt show in your logs although the logging stops, very weird.
LukaQ
I just noticed when looking at sys.log that this happened twice around that time
[10-04-17_16:16:02.379]	[LOG]
[10-04-17_16:16:15.391]	[LOG]
[10-04-17_16:16:15.393]	[LOG]
[10-04-17_16:16:15.396]	[LOG]
[10-04-17_16:16:15.401]	[LOG]
[10-04-17_16:16:27.433]	[LOG]
[10-04-17_16:16:27.440]	[LOG]
[10-04-17_16:16:27.442]	[LOG]
[10-04-17_16:16:27.443]	[LOG]
[10-04-17_16:16:27.445]	[LOG]
[10-04-17_16:16:27.451]	[LOG]
[10-04-17_16:16:51.474]	[LOG]
[10-04-17_16:16:51.477]	[LOG]
[10-04-17_16:16:51.479]	[LOG]
[10-04-17_16:16:51.480]	[LOG]
[10-04-17_16:16:51.481]	[LOG]
[10-04-17_16:16:51.487]	[LOG]
[10-04-17_16:17:16.516]	[LOG]
[10-04-17_16:17:16.520]	[LOG]
[10-04-17_16:17:16.521]	[LOG]
[10-04-17_16:17:16.522]	[LOG]
[10-04-17_16:17:16.523]	[LOG]
[10-04-17_16:17:16.529]	[LOG]
[10-04-17_16:17:40.556]	[LOG]
[10-04-17_16:17:40.559]	[LOG]
[10-04-17_16:17:40.560]	[LOG]
[10-04-17_16:17:40.561]	[LOG]
[10-04-17_16:17:40.563]	[LOG]
[10-04-17_16:17:40.569]	[LOG]
[10-04-17_16:18:05.598]	[LOG]
[10-04-17_16:18:05.601]	[LOG]
[10-04-17_16:18:05.603]	[LOG]
[10-04-17_16:18:05.604]	[LOG]
[10-04-17_16:18:05.605]	[LOG]
[10-04-17_16:18:05.616]	[LOG]
[10-04-17_16:18:20.620]	[LOG]
[10-04-17_16:18:20.622]	[LOG]
[10-04-17_16:18:20.624]	[LOG]
[10-04-17_16:18:20.629]	[LOG]
[10-04-17_16:18:29.661]	[LOG]
[10-04-17_16:18:29.664]	[LOG]
[10-04-17_16:18:29.665]	[LOG]
[10-04-17_16:18:29.666]	[LOG]
[10-04-17_16:18:29.667]	[LOG]
[10-04-17_16:18:29.674]	[LOG]
[10-04-17_16:18:54.702]	[LOG]
[10-04-17_16:18:54.704]	[LOG]
[10-04-17_16:18:54.706]	[LOG]
[10-04-17_16:18:54.707]	[LOG]
[10-04-17_16:18:54.708]	[LOG]
[10-04-17_16:18:54.714]	[LOG]
[10-04-17_16:19:18.744]	[LOG]
[10-04-17_16:19:18.747]	[LOG]
[10-04-17_16:19:18.748]	[LOG]
[10-04-17_16:19:18.750]	[LOG]
[10-04-17_16:19:18.751]	[LOG]
[10-04-17_16:19:18.757]	[LOG]
[10-04-17_16:19:23.766]	[LOG]
[10-04-17_16:19:23.768]	[LOG]
[10-04-17_16:19:23.770]	[LOG]
[10-04-17_16:19:23.775]	[LOG]
[10-04-17_16:19:43.807]	[LOG]
[10-04-17_16:19:43.811]	[LOG]
[10-04-17_16:19:43.812]	[LOG]
[10-04-17_16:19:43.813]	[LOG]
[10-04-17_16:19:43.815]	[LOG]
[10-04-17_16:19:43.820]	[LOG]
[10-04-17_16:20:07.849]	[LOG]
[10-04-17_16:20:07.852]	[LOG]
[10-04-17_16:20:07.854]	[LOG]
[10-04-17_16:20:07.855]	[LOG]
[10-04-17_16:20:07.856]	[LOG]
[10-04-17_16:20:07.862]	[LOG]
[10-04-17_16:20:26.872]	[LOG]
[10-04-17_16:20:26.875]	[LOG]
[10-04-17_16:20:26.876]	[LOG]
[10-04-17_16:20:26.881]	[LOG]
[10-04-17_16:20:32.911]	[LOG]
[10-04-17_16:20:32.915]	[LOG]
[10-04-17_16:20:32.916]	[LOG]
[10-04-17_16:20:32.917]	[LOG]
[10-04-17_16:20:32.919]	[LOG]
[10-04-17_16:20:32.925]	[LOG]
[10-04-17_16:20:56.954]	[LOG]
[10-04-17_16:20:56.957]	[LOG]
[10-04-17_16:20:56.958]	[LOG]
[10-04-17_16:20:56.960]	[LOG]
[10-04-17_16:20:56.961]	[LOG]
[10-04-17_16:20:56.967]	[LOG]
[10-04-17_16:21:21.994]	[LOG]
[10-04-17_16:21:22.003]	[LOG]
[10-04-17_16:21:22.005]	[LOG]
[10-04-17_16:21:22.006]	[LOG]
[10-04-17_16:21:22.007]	[LOG]
[10-04-17_16:21:22.013]	[LOG]
[10-04-17_16:21:29.016]	[LOG]
[10-04-17_16:21:29.020]	[LOG]
[10-04-17_16:21:29.021]	[LOG]
[10-04-17_16:21:29.027]	[LOG]
[10-04-17_16:21:46.058]	[LOG]
[10-04-17_16:21:46.060]	[LOG]
[10-04-17_16:21:46.062]	[LOG]
[10-04-17_16:21:46.063]	[LOG]
[10-04-17_16:21:46.065]	[LOG]
[10-04-17_16:21:46.070]	[LOG]
[10-04-17_16:22:11.098]	[LOG]
[10-04-17_16:22:11.102]	[LOG]
[10-04-17_16:22:11.103]	[LOG]
[10-04-17_16:22:11.105]	[LOG]
[10-04-17_16:22:11.106]	[LOG]
[10-04-17_16:22:11.112]	[LOG]
[10-04-17_16:22:32.121]	[LOG]
[10-04-17_16:22:32.124]	[LOG]
[10-04-17_16:22:32.126]	[LOG]
[10-04-17_16:22:32.131]	[LOG]
[10-04-17_16:22:35.162]	[LOG]
[10-04-17_16:22:35.173]	[LOG]
[10-04-17_16:22:35.175]	[LOG]
[10-04-17_16:22:35.176]	[LOG]
[10-04-17_16:22:35.178]	[LOG]
[10-04-17_16:22:35.183]	[LOG]
[10-04-17_16:23:00.203]	[LOG]
[10-04-17_16:23:00.206]	[LOG]
[10-04-17_16:23:00.207]	[LOG]
[10-04-17_16:23:00.209]	[LOG]
[10-04-17_16:23:00.210]	[LOG]
[10-04-17_16:23:00.216]	[LOG]
[10-04-17_16:23:24.244]	[LOG]
[10-04-17_16:23:24.247]	[LOG]
[10-04-17_16:23:24.248]	[LOG]
[10-04-17_16:23:24.249]	[LOG]
[10-04-17_16:23:24.250]	[LOG]
[10-04-17_16:23:24.256]	[LOG]
[10-04-17_16:23:35.266]	[LOG]
[10-04-17_16:23:35.268]	[LOG]
[10-04-17_16:23:35.270]	[LOG]
[10-04-17_16:23:35.275]	[LOG]
[10-04-17_16:23:48.308]	[LOG]
[10-04-17_16:23:48.310]	[LOG]
[10-04-17_16:23:48.312]	[LOG]
[10-04-17_16:23:48.313]	[LOG]
[10-04-17_16:23:48.314]	[LOG]
[10-04-17_16:23:48.320]	[LOG]
[10-04-17_16:24:13.347]	[LOG]
[10-04-17_16:24:13.350]	[LOG]
[10-04-17_16:24:13.352]	[LOG]
[10-04-17_16:24:13.353]	[LOG]
[10-04-17_16:24:13.354]	[LOG]
[10-04-17_16:24:13.360]	[LOG]
[10-04-17_16:24:37.369]	[LOG]
[10-04-17_16:24:37.372]	[LOG]
[10-04-17_16:24:37.373]	[LOG]
[10-04-17_16:24:37.379]	[LOG]
[10-04-17_16:25:02.411]	[LOG]
[10-04-17_16:25:02.416]	[LOG]
[10-04-17_16:25:02.417]	[LOG]
[10-04-17_16:25:02.418]	[LOG]
[10-04-17_16:25:02.422]	[LOG]
[10-04-17_16:25:27.453]	[LOG]
[10-04-17_16:25:27.457]	[LOG]
[10-04-17_16:25:27.458]	[LOG]
[10-04-17_16:25:27.459]	[LOG]
[10-04-17_16:25:27.460]	[LOG]
[10-04-17_16:25:27.466]	[LOG]
[10-04-17_16:25:40.475]	[LOG]
[10-04-17_16:25:40.478]	[LOG]
[10-04-17_16:25:40.480]	[LOG]
[10-04-17_16:25:40.486]	[LOG]
[10-04-17_16:25:51.516]	[LOG]
[10-04-17_16:25:51.519]	[LOG]
[10-04-17_16:25:51.521]	[LOG]
[10-04-17_16:25:51.522]	[LOG]
[10-04-17_16:25:51.523]	[LOG]
[10-04-17_16:25:51.530]	[LOG]
[10-04-17_16:26:15.556]	[LOG]
[10-04-17_16:26:15.559]	[LOG]
[10-04-17_16:26:15.560]	[LOG]
[10-04-17_16:26:15.563]	[LOG]
[10-04-17_16:26:15.564]	[LOG]
[10-04-17_16:26:15.570]	[LOG]
[10-04-17_16:26:40.599]	[LOG]
[10-04-17_16:26:40.609]	[LOG]
[10-04-17_16:26:40.610]	[LOG]
[10-04-17_16:26:40.611]	[LOG]
[10-04-17_16:26:40.613]	[LOG]
[10-04-17_16:26:40.619]	[LOG]
[10-04-17_16:26:43.622]	[LOG]
[10-04-17_16:26:43.625]	[LOG]
[10-04-17_16:26:43.626]	[LOG]
[10-04-17_16:26:43.633]	[LOG]
[10-04-17_16:27:04.661]	[LOG]
[10-04-17_16:27:04.664]	[LOG]
[10-04-17_16:27:04.666]	[LOG]
[10-04-17_16:27:04.667]	[LOG]
[10-04-17_16:27:04.668]	[LOG]
[10-04-17_16:27:04.675]	[LOG]
[10-04-17_16:27:29.706]	[LOG]
[10-04-17_16:27:29.710]	[LOG]
[10-04-17_16:27:29.711]	[LOG]
[10-04-17_16:27:29.712]	[LOG]
[10-04-17_16:27:29.714]	[LOG]
[10-04-17_16:27:29.719]	[LOG]
[10-04-17_16:27:45.728]	[LOG]
[10-04-17_16:27:45.731]	[LOG]
[10-04-17_16:27:45.732]	[LOG]
[10-04-17_16:27:45.739]	[LOG]
[10-04-17_16:27:53.768]	[LOG]
[10-04-17_16:27:53.771]	[LOG]
[10-04-17_16:27:53.772]	[LOG]
[10-04-17_16:27:53.774]	[LOG]
[10-04-17_16:27:53.775]	[LOG]
[10-04-17_16:27:53.782]	[LOG]
[10-04-17_16:28:18.809]	[LOG]
[10-04-17_16:28:18.812]	[LOG]
[10-04-17_16:28:18.813]	[LOG]
[10-04-17_16:28:18.815]	[LOG]
[10-04-17_16:28:18.816]	[LOG]
[10-04-17_16:28:18.822]	[LOG]
[10-04-17_16:28:42.849]	[LOG]
[10-04-17_16:28:42.852]	[LOG]
[10-04-17_16:28:42.853]	[LOG]
[10-04-17_16:28:42.854]	[LOG]
[10-04-17_16:28:42.857]	[LOG]
[10-04-17_16:28:42.863]	[LOG]
[10-04-17_16:28:48.871]	[LOG]
[10-04-17_16:28:48.879]	[LOG]
[10-04-17_16:28:48.880]	[LOG]
[10-04-17_16:28:48.886]	[LOG]
[10-04-17_16:29:07.920]	[LOG]
[10-04-17_16:29:07.923]	[LOG]
[10-04-17_16:29:07.924]	[LOG]
[10-04-17_16:29:07.925]	[LOG]
[10-04-17_16:29:07.926]	[LOG]
[10-04-17_16:29:07.933]	[LOG]
[10-04-17_16:29:31.978]	[LOG]
[10-04-17_16:29:31.983]	[LOG]
[10-04-17_16:29:31.984]	[LOG]
[10-04-17_16:29:31.986]	[LOG]
[10-04-17_16:29:31.987]	[LOG]
[10-04-17_16:29:31.994]	[LOG]
[10-04-17_16:29:51.994]	[LOG]
[10-04-17_16:29:51.998]	[LOG]
[10-04-17_16:29:51.999]	[LOG]
[10-04-17_16:29:52.006]	[LOG]
[10-04-17_16:29:57.047]	[LOG]
[10-04-17_16:29:57.054]	[LOG]
[10-04-17_16:29:57.056]	[LOG]
[10-04-17_16:29:57.057]	[LOG]
[10-04-17_16:29:57.059]	[LOG]
[10-04-17_16:29:57.065]	[LOG]
[10-04-17_16:17:20.690]	[INFO]
[10-04-17_16:17:20.709]	[INFO]
[10-04-17_16:17:32.891]	[LOG]
[10-04-17_16:17:32.924]	[LOG]
[10-04-17_16:17:32.948]	[LOG]
[10-04-17_16:17:32.949]	[ERROR]
[10-04-17_16:17:32.954]	[LOG]
[10-04-17_16:17:32.973]	[LOG]
[10-04-17_16:17:32.998]	[LOG]
[10-04-17_16:17:41.914]	[LOG]
[10-04-17_16:17:41.922]	[LOG]
[10-04-17_16:17:41.936]	[LOG]
[10-04-17_16:17:41.948]	[LOG]
[10-04-17_16:17:56.956]	[LOG]
[10-04-17_16:17:56.960]	[LOG]
[10-04-17_16:17:56.962]	[LOG]
[10-04-17_16:17:56.963]	[ERROR]
[10-04-17_16:17:56.965]	[LOG]
[10-04-17_16:17:56.967]	[LOG]
[10-04-17_16:17:56.975]	[LOG]
[10-04-17_16:18:22.016]	[LOG]
[10-04-17_16:18:22.020]	[LOG]
[10-04-17_16:18:22.027]	[LOG]
[10-04-17_16:18:22.031]	[ERROR]
[10-04-17_16:18:22.033]	[LOG]
[10-04-17_16:18:22.040]	[LOG]
[10-04-17_16:18:22.053]	[LOG]
[10-04-17_16:18:44.082]	[LOG]
[10-04-17_16:18:44.086]	[LOG]
[10-04-17_16:18:44.088]	[LOG]
[10-04-17_16:18:44.100]	[LOG]
[10-04-17_16:18:46.134]	[LOG]
[10-04-17_16:18:46.140]	[LOG]
[10-04-17_16:18:46.143]	[LOG]
[10-04-17_16:18:46.144]	[ERROR]
[10-04-17_16:18:46.145]	[LOG]
[10-04-17_16:18:46.147]	[LOG]
[10-04-17_16:18:46.156]	[LOG]
[10-04-17_16:19:11.183]	[LOG]
[10-04-17_16:19:11.186]	[LOG]
[10-04-17_16:19:11.195]	[LOG]
[10-04-17_16:19:11.199]	[ERROR]
[10-04-17_16:19:11.205]	[LOG]
[10-04-17_16:19:11.207]	[LOG]
[10-04-17_16:19:11.218]	[LOG]
[10-04-17_16:19:35.228]	[LOG]
[10-04-17_16:19:35.232]	[LOG]
[10-04-17_16:19:35.234]	[LOG]
[10-04-17_16:19:35.235]	[ERROR]
[10-04-17_16:19:35.239]	[LOG]
[10-04-17_16:19:35.241]	[LOG]
[10-04-17_16:19:35.251]	[LOG]
[10-04-17_16:19:47.250]	[LOG]
[10-04-17_16:19:47.254]	[LOG]
[10-04-17_16:19:47.262]	[LOG]
[10-04-17_16:19:47.270]	[LOG]
[10-04-17_16:20:00.294]	[LOG]
[10-04-17_16:20:00.306]	[LOG]
[10-04-17_16:20:00.308]	[LOG]
[10-04-17_16:20:00.309]	[ERROR]
[10-04-17_16:20:00.311]	[LOG]
[10-04-17_16:20:00.312]	[LOG]
[10-04-17_16:20:00.320]	[LOG]
[10-04-17_16:20:24.335]	[LOG]
[10-04-17_16:20:24.339]	[LOG]
[10-04-17_16:20:24.341]	[LOG]
[10-04-17_16:20:24.345]	[ERROR]
[10-04-17_16:20:24.346]	[LOG]
[10-04-17_16:20:24.348]	[LOG]
[10-04-17_16:20:24.355]	[LOG]
[10-04-17_16:20:49.383]	[LOG]
[10-04-17_16:20:49.387]	[LOG]
[10-04-17_16:20:49.389]	[LOG]
[10-04-17_16:20:49.390]	[ERROR]
[10-04-17_16:20:49.391]	[LOG]
[10-04-17_16:20:49.393]	[LOG]
[10-04-17_16:20:49.399]	[LOG]
[10-04-17_16:21:13.424]	[LOG]
[10-04-17_16:21:13.427]	[LOG]
[10-04-17_16:21:13.429]	[LOG]
[10-04-17_16:21:13.430]	[ERROR]
[10-04-17_16:21:13.431]	[LOG]
[10-04-17_16:21:13.433]	[LOG]
[10-04-17_16:21:13.439]	[LOG]
[10-04-17_16:21:38.477]	[LOG]
[10-04-17_16:21:38.480]	[LOG]
[10-04-17_16:21:38.482]	[LOG]
[10-04-17_16:21:38.483]	[ERROR]
[10-04-17_16:21:38.484]	[LOG]
[10-04-17_16:21:38.486]	[LOG]
[10-04-17_16:21:38.493]	[LOG]
[10-04-17_16:21:52.508]	[LOG]
[10-04-17_16:21:52.511]	[LOG]
[10-04-17_16:21:52.513]	[LOG]
[10-04-17_16:21:52.521]	[LOG]
[10-04-17_16:22:02.549]	[LOG]
[10-04-17_16:22:02.554]	[LOG]
[10-04-17_16:22:02.556]	[LOG]
[10-04-17_16:22:02.557]	[ERROR]
[10-04-17_16:22:02.560]	[LOG]
[10-04-17_16:22:02.562]	[LOG]
[10-04-17_16:22:02.574]	[LOG]
[10-04-17_16:22:27.596]	[LOG]
[10-04-17_16:22:27.602]	[LOG]
[10-04-17_16:22:27.605]	[LOG]
[10-04-17_16:22:27.607]	[ERROR]
[10-04-17_16:22:27.608]	[LOG]
[10-04-17_16:22:27.609]	[LOG]
[10-04-17_16:22:27.616]	[LOG]
[10-04-17_16:22:51.638]	[LOG]
[10-04-17_16:22:51.641]	[LOG]
[10-04-17_16:22:51.644]	[LOG]
[10-04-17_16:22:51.645]	[ERROR]
[10-04-17_16:22:51.646]	[LOG]
[10-04-17_16:22:51.650]	[LOG]
[10-04-17_16:22:51.657]	[LOG]
[10-04-17_16:22:55.660]	[LOG]
[10-04-17_16:22:55.663]	[LOG]
[10-04-17_16:22:55.665]	[LOG]
[10-04-17_16:22:55.671]	[LOG]
[10-04-17_16:17:21.864]	[INFO]
[10-04-17_16:17:21.883]	[INFO]
[10-04-17_16:17:23.025]	[LOG]
[10-04-17_16:17:23.046]	[LOG]
[10-04-17_16:17:23.065]	[LOG]
[10-04-17_16:17:23.066]	[ERROR]
[10-04-17_16:17:23.069]	[LOG]
[10-04-17_16:17:23.084]	[LOG]
[10-04-17_16:17:23.115]	[LOG]
[10-04-17_16:37:03.757]	[INFO]
[10-04-17_16:37:03.769]	[INFO]
[10-04-17_16:37:11.730]	[LOG]
[10-04-17_16:37:11.735]	[LOG]
[10-04-17_16:37:11.742]	[LOG]
[10-04-17_16:37:11.757]	[LOG]
[10-04-17_16:37:18.796]	[LOG]
[10-04-17_16:37:18.801]	[LOG]
[10-04-17_16:37:18.803]	[LOG]
[10-04-17_16:37:18.804]	[ERROR]
[10-04-17_16:37:18.805]	[LOG]
[10-04-17_16:37:18.810]	[LOG]
[10-04-17_16:37:18.819]	[LOG]
[10-04-17_16:37:42.835]	[LOG]
[10-04-17_16:37:42.838]	[LOG]
[10-04-17_16:37:42.846]	[LOG]
[10-04-17_16:37:42.847]	[ERROR]
[10-04-17_16:37:42.852]	[LOG]
[10-04-17_16:37:42.855]	[LOG]
[10-04-17_16:37:42.874]	[LOG]
[10-04-17_16:38:07.884]	[LOG]
[10-04-17_16:38:07.889]	[LOG]
[10-04-17_16:38:07.890]	[LOG]
[10-04-17_16:38:07.890]	[ERROR]
[10-04-17_16:38:07.892]	[LOG]
[10-04-17_16:38:07.894]	[LOG]
[10-04-17_16:38:07.907]	[LOG]
[10-04-17_16:38:13.913]	[LOG]
[10-04-17_16:38:13.917]	[LOG]
[10-04-17_16:38:13.919]	[LOG]
[10-04-17_16:38:13.927]	[LOG]
[10-04-17_16:38:31.962]	[LOG]
[10-04-17_16:38:31.966]	[LOG]
[10-04-17_16:38:31.968]	[LOG]
[10-04-17_16:38:31.969]	[ERROR]
First it went to 16:29, then jumped to 16:17 (where error started to show up), then went up 16:22, jumped again to 16:17 and the made another jump to 16:37. So on first time jump, H developed that error, while other 3 data sets were totally fine. This really was write error (or corruption, but I don't know how only 2 bytes would be affected on SD card or is it just my luck)
A check in logutil.js is good for BEFORE write, nothing to check if it was actually written. In any case, this partial data in my mind is almost impossible to get, so I don't think there you need to do anything.
Problem like I showed in other thread, which is related to whole line of 9 byte to be 0 could be something to work on, IF there is some simple way (bash script or something).
Alternative to this would be to have option to view data as table  ;D, you could see erroneous data this way. Again, I suspect a lot of hard if you go and do this. Maybe put it on todo list.
This is SD corruption most likely. In which case no amount of checking or seeing data in a table will help. When the hard drive itself is rotten, it's hopeless, it cannot self heal by error checking. This will keep on happening, and we will wonder where the invisible bug is. It's hardware from all indications, that easily explains all this trouble.
I have seen my own bad SD cards continue to write data in a very weird way, some files would be fine, others I could not even open or copy over FTP. It took me a while to realize the SD was indeed bad, I looked elsewhere because the Gateway app sort of kept working and I thought "how can I have a bad SD card if the app is running". But very strange phenomena was happening. Until I changed to a different SD brand and never had issues again.
LukaQ
Sure, that is a possible explanation indeed. Do you have any prefered software to check SD card or you just replace it?
The answer depends how much more of your life you want to spend on this problem ;)
In my case I just replaced the SD card.
