Gateway not showing nodes
Started by jeremiah, February 04, 2016, 01:24:08 AM
jeremiah
So I have been uploading the MightyHat Sketch through the Pi with avrdude. Using arduino app I open the default sketch and make the setup changes. I then choose "Export Compiled Binary" to the .hex file to put on the Pi. It actually creates 2 files of .hex
MightyHat.ino.with_bootloader.arduino_standard.hex
and
MightyHat.ino.arduino_standard.hex
Is there a correct one to use?
Also, going back to look at the actual hardware i ordered. I am noticing that the Motenio USB is a RFM96W (433mhz)
and my MightyHat is a RFM96 (LoRa 433mhz)
Could that be the issue? I thought the transeiver guide said the LoRa ones talked to all the older versions.
#16
Well, that would totally explain it. RFM96 (LoRa radios) cannot talk to RFM69.
On this page I explain the differences and I have this statement: "they cannot communicate with any RFM69 radios (except via a bridge module between two such networks is built). In other words, they are a completely different type of radio for a different category of communications."
I do not have a sample sketch for MightyHat with LoRa radios at this time. It was simply an extra feature of the MightyHat to allow RFM95/96 radios to be soldered on them.
Sorry if this is not more transparent or obvious.
The way I program the Hat is I enable output on compilation from File>Preferences, that gives the output hex path.
I copy that hex to my Pi via FTP and then I use avrdude as shown on the MightyHat programming page.
jeremiah
Any chance I can swap the LoRo tranceiver for a RFM69 on my existing MightyHat? Or do I have to eat the cost of that whole thing an buy a whole new MightyHat?
Sure you can swap it. You will need to do that carefully not to lift the pads off of it. I use 2 soldering irons with 16mm wide tips to lift the radio at the same time.
If you want to, I can do this for you at no charge, provided you cover the shipping and new radio cost (about $10). That's more economical than getting a new Hat.
Let me know if that offer is something that will work for you.
jeremiah
That would be awesome Felix. I appreciate the offer to do that. Let me know how we can take care of that.
My pleasure,
Please email me at felix at this domain or through the contact form, or reply to your last order email and I'll get you instructions.
