Request: Voltage parameter for low battery warning [done in v8.10.0]
Started by Lukapple, August 24, 2017, 08:00:51 AM
Lukapple
Ok latest commit includes the new battery warning setting and changes.
The other changes also require you run npm install and you migrate your settings to the new settings.json5 because that has changed significantly.
I suggest backing up your Pi image in case something goes wrong.
Lukapple
Lukapple
Tested voltage setting and send mail attachment parameter and it works fine ;D
