"Cannot read Property error" when adding event
Started by sparky, January 04, 2020, 12:23:12 PM
sparky
In trying to create an event as shown in the following thread;
https://lowpowerlab.com/forum/pi-gateway/dynamic-node-specific-event-trigger/msg21232/#msg21232
I keep getting the following error in the gateway.sys.log;
[01-04-20_10:53:30.630] [WARN]   Event tempTooColdSMSLimiter execution failed: Cannot read property 'lowTempValue' of undefined
[01-04-20_10:53:30.633] [WARN]   Event tempTooHotSMSLimiter execution failed: Cannot read property 'highTempValue' of undefined
The following was added to exports.events;
tempTooColdSMSLimiter : { label:'TooColdAlert : SMS', icon:'comment', descr:'Send SMS when Temp is < than the lowValue setting, once per 30 min.',
      if (node.metrics['F'] && node.metrics['F'].value < node.settings['lowTempValue'] && (Date.now() - node.metrics['F'].updated < 2000)) /*check if M metric exists and value is MOTION, received less than 2s ago*/
        var approveSMS = false;
        if (node.metrics['F'].lastSMS) /*check if lastSMS value is not NULL ... */
          if (Date.now() - node.metrics['F'].lastSMS > 1800000) /*check if lastSMS timestamp is more than 1hr ago */
            approveSMS = true;
        else
          approveSMS = true;
        if (approveSMS)
          node.metrics['F'].lastSMS = Date.now();
          sendSMS('Too cold!', 'Temperature alert on: [' + node._id + '] :' + node.label.replace(/\{.+\}/ig, '') + ' @ ' + new Date().toLocaleTimeString());
          db.update({ _id: node._id }, { $set : node}, {}, function (err, numReplaced) { console.log('   ['+node._id+'] DB-Updates:' + numReplaced);}); /*save lastSMS timestamp to DB*/
        else console.log('   ['+node._id+'] TooColdAlert SMS skipped.');
  tempTooHotSMSLimiter : { label:'TooHotAlert : SMS', icon:'comment', descr:'Send SMS when Temp is > than the highValue setting, once per 30 min.',
      if (node.metrics['F'] && node.metrics['F'].value > node.settings['highTempValue'] && (Date.now() - node.metrics['F'].updated < 2000)) /*check if M metric exists and value is MOTION, received less than 2s ago*/
          if (Date.now() - node.metrics['F'].lastSMS > 1800000) /*check if lastSMS timestamp is more than 1hr ago*/
            approveSMS = true;
        else
          approveSMS = true;
        if (approveSMS)
          sendSMS('Too hot!', 'Temperature alert on: [' + node._id + '] :' + node.label.replace(/\{.+\}/ig, '') + ' @ ' + new Date().toLocaleTimeString());
        else console.log('   ['+node._id+'] TooHotAlert SMS skipped.');
The following was added to exports.motes;
    settings: { ip:'',
	lowTempValue: '',
    highTempValue: ''}, //blank will inherit ip value from global settings.json
and this is the section of the system.json5 file that was edited;
radiothermostat: {
      editable: true,
      exposed: true,
      ip: {
        value: '10.0.0.41',
        description: 'If you have a wifi RadioThermostat CT50/CT80 this is the IP address',
	  lowTempValue: {
        value: 68,
        type: 'range',
        min:32,
        max:75,
        description: 'Send SMS when Temp is < than the lowValue setting, once per 30 min.'
      highTempValue: {
        value: 75,
        type: 'range',
        min:50,
        max:90,
        description: 'Send SMS when Temp is > than the highValue setting, once per 30 min.'
Any help into what I have done wrong would be greatly appreciated.  Thank you!
Attached are a couple screenshots from phone.
ssmall
Try node.settings['lowTempValue'].min
And node.settings['highTempValue'].max
sparky
ssmall,
Thanks for the reply..
I'm getting the same results;
      if (node.metrics['F'] && node.metrics['F'].value < node.settings['lowTempValue'].min && (Date.now() - node.metrics['F'].updated < 2000)) /*check if M metric exists and value is MOTION, received less than 2s ago*/
            approveSMS = true;
        else
          approveSMS = true;
        if (approveSMS)
      if (node.metrics['F'] && node.metrics['F'].value > node.settings['highTempValue'].max && (Date.now() - node.metrics['F'].updated < 2000)) /*check if M metric exists and value is MOTION, received less than 2s ago*/
            approveSMS = true;
        else
          approveSMS = true;
        if (approveSMS)
[01-04-20_14:59:45.420] [WARN]   Event tempTooColdSMSLimiter execution failed: Cannot read property 'lowTempValue' of undefined
[01-04-20_14:59:45.421] [WARN]   Event tempTooHotSMSLimiter execution failed: Cannot read property 'highTempValue' of undefined
ssmall
Try  node.settings.radiothermostat.lowTempValue.min
Or
node.settings.lowTempValue
sparky
No luck..
[01-04-20_16:02:56.333] [WARN]   Event tempTooColdSMSLimiter execution failed: Cannot read property 'radiothermostat' of undefined
[01-04-20_16:02:56.334] [WARN]   Event tempTooHotSMSLimiter execution failed: Cannot read property 'radiothermostat' of undefined
[01-04-20_16:06:37.475] [WARN]   Event tempTooColdSMSLimiter execution failed: Cannot read property 'lowTempValue' of undefined
[01-04-20_16:06:37.479] [WARN]   Event tempTooHotSMSLimiter execution failed: Cannot read property 'highTempValue' of undefined
I suggest following existing patterns when in doubt.
Here's a good example event that uses a setting at the node level - motionEmailSnapshot.
Note the search for existing database node and the callback which yields the result (dbNode), and how that is checked for empty and default handling of the ipcam_snapURL  setting:
  motionEmailSnapshot : { label:'Motion : Email+IPCam Snapshot', icon:'camera', descr:'Send email when MOTION is detected, with snapshot from IPCamera',
      if (node.metrics['M'] && node.metrics['M'].value == 'MOTION' && (Date.now() - new Date(node.metrics['M'].updated).getTime() < 2000))
        db.findOne({ _id : node._id }, function (err, dbNode) {
          var snapshotURL = dbNode.settings && dbNode.settings.ipcam_snapURL ? dbNode.settings.ipcam_snapURL : (exports.motes[dbNode.type].settings.ipcam_snapURL || settings.misc.ipcam_snapURL.value);
          sendEmail('MOTION DETECTED', 'MOTION DETECTED ON NODE: [' + dbNode._id + ':' + dbNode.label.replace(/\{.+\}/ig, '') + '] @ ' + new Date().toLocaleTimeString(), [{path: snapshotURL, filename: 'snapshot.jpg'}]);
sparky
#6
Thanks for your reply Felix..
That Event looks a little over my head.  I'll try but I might have to wait until I return to tackle it
Edit:
Ok, tried it this morning.. although I'm not getting the error message in the log any longer I am also not getting any indication that the Event is running
tempTooColdTSMSLimiter : { label:'TooColdTAlert : SMS', icon:'comment', descr:'Send SMS when Temp is < than the lowValue setting, once per 30 min.',
      if (node.metrics['F'] && node.metrics['F'].value == 'lowTempValue' && (Date.now() - new Date(node.metrics['F'].updated).getTime() < 2000))
          var tempTooCold = dbNode.settings && dbNode.settings.lowTempValue ? dbNode.settings.lowTempValue : (exports.motes[dbNode.type].settings.lowTempValue || settings.radiothermostat.lowTempValue.value);
          sendEmail('Too cold!', 'Temperature alert on: [' + dbNode._id + ':' + dbNode.label.replace(/\{.+\}/ig, '') + '] @ ' + new Date().toLocaleTimeString() );
It's running if it's enabled in the UI and it turns green.
Add more logging to determine where it's not doing what you want.
sparky
Ok so bugs solved. Now its time to debug your code and see where it doesn't do what you need.
Logging is your best friend there.
sparky
Ok Thanks Felix,
This programming is pretty easy for some of you but it isn't for me.  I'll have to read up on debugging with code..
Just add logging statements as you see in other places in the code... doesn't get much easier than that.
sparky
Quote from: sparky on January 09, 2020, 01:40:13 PM
Ouch, right to the gut!
Well, if you see it that way ...  ::)
Even in the first post you added in this thread, basically the second was written by you  :-X
sparky
Well as I've said many times on this forum; this programming is all new to me and that's it's been a real struggle trying to learn it.  So when someone makes a statement "doesn't get much easier than that" I feel it's pretty demeaning.
In regards to the code you just posted, yes I did indeed post that in my first post but it was posted from a user named fix which I also provided a link to.  Now If your saying this is the kind of code I'm to add to try and figure out why my code is not working then I'll have to read up on debugging code as already stated.
I thank you and ssmall again for trying to help me with this!  It is appreciated.
