Hardware support => Moteino => Topic started by: vikas60vas on January 09, 2014, 11:30:15 AM
Title: Using RFM69hw with Arduino uno r3 board (not with Moteino)
Post by: vikas60vas on January 09, 2014, 11:30:15 AM
Hello!!
I have started to use RFM69hw with arduino uno board. I have made small board for RFM69hw and i am able to read register values of RFM69hw using arduino uno board (that means connections between uno and RFM69hw is correct). But gateway.ino and node.ino is not working.
Is there any addtional stuff needed to use RFM69hw with Arduino uno board if i dont use Moteino?
Please help..
Title: Re: Using RFM69hw with Arduino uno r3 board (not with Moteino)
Post by: Felix on January 09, 2014, 11:52:42 AM
We will need a lot more detail than "it does not work". But please start by checking around the forum, there have been a few folks who tried the same thing with good results.
Post by: vikas60vas on January 10, 2014, 01:45:15 AM
After i try to call RGM69.send() function, it draws lots of power and becomes power down in chip.. what should be the reason?
Post by: bingo600 on January 10, 2014, 03:52:55 PM
Quote from: vikas60vas on January 10, 2014, 01:45:15 AM
5v perhaps ?
Isn't the RFM69 a 3v3 device ?
/Bingo
Post by: pko on January 11, 2014, 04:20:50 AM
This had been discussed in a previous thread.  Arduino Uno can only supply 50mA current on its 3.3V power rail.  The RFM69HW uses typical 130mA on transmit.  If you are powering the RFM69HW from the 3.3V power rail of the Uno, then you are asking for trouble.
Post by: Felix on January 11, 2014, 05:04:42 PM
Quote from: pko on January 11, 2014, 04:20:50 AM
Good observation!
