Hardware support => Moteino => Topic started by: joelucid on June 12, 2015, 02:49:04 AM
Title: Reviving Moteino after applying 9V in reverse
Post by: joelucid on June 12, 2015, 02:49:04 AM
Ok, Felix recently said it's unlikely that someone would apply power in reverse to the Moteino - but it happened to me some time ago. Today I thought that this probably just fried (sorry, Tom, toasted ...) the voltage regulator. So I applied 3V directly at the 3.3V pin. And yes, the moteino came back to life. However it now drew >70mA.
I soldered off the power regulator and the Vin cap - but it's still at 70mA. Should I just forget about this one or do you have other suggestions about how to proceed?
Title: Re: Reviving Moteino after applying 9V in reverse
Post by: Felix on June 12, 2015, 08:18:46 AM
Replace regulator. MCP1703 3.3V
Post by: joelucid on June 13, 2015, 03:23:24 PM
How could that help if I can't make the Moteino work properly at 3V / 8mhz without the regulator?
Post by: Felix on June 14, 2015, 04:03:02 PM
Is the bad regulator still soldered?
Did you do *anything* other than hooking up >3.5V on the "VIN" pin? If so that might have damaged it.
Post by: TomWS on June 14, 2015, 04:46:04 PM
Quote from: Felix on June 14, 2015, 04:03:02 PM
I believe he did remove the VR from:
Quote from: joelucid on June 12, 2015, 02:49:04 AM
[/quote]
Post by: joelucid on June 15, 2015, 09:11:44 AM
No, I removed first the regulator, then the large cap. That didn't change the large current consumption at the 3.3V input. I then removed the flash memory chip I had on the moteino. Afterwards power consumption was a bit lower - but now I can no longer flash the uC using my mkII.
I checked the board using a magnifying glass and thoroughly cleansed it in ethanol, but no change. I'll write this moteino off unless there are other ideas.
This was a new Moteino, I just applied -9V to VIN and the regulator went up in smoke. My hope had been that it had acted as "fuse" protecting the other circuits. Apparently not.
Post by: Felix on June 15, 2015, 12:18:06 PM
RFM69 boards need a pullup on CS (D10) if you want to reflash them with a MKii or they can garble your programming of the mega.
"3.3" would be the output of the regulator and input to the mega/flash/radio. If you had those devices on the board when the killer voltage was applied, then those might have fried as well and cause the consumption you see.
Otherwise ... I would declare it dead and move on, everything you're describing are symptoms of a damaged moteino.
