Hardware support => Moteino => Topic started by: Kitsibas on September 24, 2014, 10:33:27 AM
Title: Problem with data transmission
Post by: Kitsibas on September 24, 2014, 10:33:27 AM
i have two sketchs:
Sender:
#include "LowPower.h"
#include <RFM69.h>
#include <SPI.h>
#include <SPIFlash.h>
#include <dht.h>
#define NODEID      99
#define NETWORKID   100
#define GATEWAYID   1
#define FREQUENCY   RF69_433MHZ //Match this with the version of your Moteino! (others: RF69_433MHZ, RF69_868MHZ)
#define KEY         "thisIsEncryptKey" //has to be same 16 characters/bytes on all nodes, not more not less!
#define LED         9
#define SERIAL_BAUD 115200
#define ACK_TIME    30  // # of ms to wait for an ack
dht DHT;
RFM69 radio;
int count = 1;
  Serial.begin(SERIAL_BAUD);
  radio.encrypt(KEY);
    int chk = DHT.read22(6);
    int temp = DHT.temperature * 100;
    int humi = DHT.humidity * 100;
    if(count > 1000) {
        count = 1;
    String string = "{\"sensorId\": ";
    string += NODEID;
    string += ", \"series\": ";
    string += count;
    string += ", \"values\":[";
    string += temp;
    string += ", ";
    string += humi;
    string += ", 0, 0, 0]";
    string += ", \"volts\": 0}";
    char msg[string.length()+1];
    string.toCharArray(msg, string.length()+1);
    Serial.println(msg);
    if(radio.sendWithRetry(GATEWAYID, msg, sizeof(msg))) {
          Serial.print("ok");
    } else {
          Serial.print("nothing");
    Serial.println();
    count++;
    Blink(LED,3);
    Serial.flush();
    radio.sleep();
    //LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
  pinMode(PIN, OUTPUT);
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
Recaiver:
#include <RFM69.h>
#include <SPI.h>
#define NODEID      1
#define LED         9
RFM69 radio;
SPIFlash flash(8, 0xEF30); //EF40 for 16mbit windbond chip
bool promiscuousMode = true; //set to 'true' to sniff all packets on the same network
  delay(10);
  //radio.setHighPower(); //uncomment only for RFM69HW!
  radio.encrypt(KEY);
  radio.promiscuous(promiscuousMode);
  char buff[50];
  sprintf(buff, "\nListening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(buff);
byte ackCount=0;
  if (radio.receiveDone())
    for (byte i = 0; i < radio.DATALEN; i++) {
    Serial.println("");
    if (radio.ACKRequested())
      radio.sendACK();
    Blink(LED,3);
  delay(DELAY_MS);
There are two problems.
1. receiver gets not complete data () like this:
{"sensorId": 99, "series": 9, "values":[2520, 3770, 0, 0, 0],
{"sensorId": 99, "series": 10, "values":[2520, 3750, 0, 0, 0]
Sender Serial.println(msg); return correct: {"sensorId": 101, "series": 1, "values":[31172, 31172, 0, 0, 0], "volts": 0}
2. recaiver not always send ACK
sender logs:
ok
{"sensorId": 99, "series": 10, "values":[2510, 3790, 0, 0, 0], "volts": 0}
nothing
{"sensorId": 99, "series": 11, "values":[2510, 3830, 0, 0, 0], "volts": 0}
nothing
{"sensorId": 99, "series": 12, "values":[2510, 3710, 0, 0, 0], "volts": 0}
ok
{"sensorId": 99, "series": 13, "values":[2510, 3780, 0, 0, 0], "volts": 0}
ok
Could someone tell me where i do mistakes?
Title: Re: Problem with data transmission
Post by: kiwisincebirth on September 24, 2014, 12:13:37 PM
There are a couple of issues.
First: There is a limit on the amount of data you can send in a singe message (the following is from the RFM Library)
#define RF69_MAX_DATA_LEN 61 // to take advantage of the built in AES/CRC we want to limit the frame size to the internal FIFO size (66 bytes - 3 bytes overhead)
I think you are going over this limit.
Second: The way you do string concatenation could be fragmenting SRAM. You need to reserve() memory for String's upfront, the documentation gives a good example - http://arduino.cc/en/Reference/StringReserve - There is also a very good article, which dscribes the constraints, issues (and fixes) for the memory poor Arduino
https://learn.adafruit.com/memories-of-an-arduino?view=all
Third: (Related Issue) Sending large String's over the air, will GULP your battery, you need to send as little as possible.
Solution: Send C Structures over he air, not strings. See This thread, Felix has some good example sketches which he links to in his response
https://lowpowerlab.com/forum/index.php/topic,94.0.html
