Moteino WeatherNode won't wake up
Started by Tony Weil, August 21, 2017, 08:45:48 AM
Maybe faulty radio(s) but that would be a long shot. Again, can't really put a diagnosis until I can see this happen and try to debug myself.
If you need to send these for me to look at, please contact me directly.
kni
All,
Since the symptoms in this thread closely match a similar problem I was experiencing, I thought I'd link to the thread I created here in case it helps:
https://lowpowerlab.com/forum/moteino/one-solution-to-moteino-failure-to-return-from-sleep/
If it does not, then sorry for the noise.
Tony Weil
Thanks a lot. I read through your post and it has a lot of possibilities. It makes sense it would be some obscure firmware issue. I have tried so many different pieces of relatively simple  Moteino/Weathershield hardware and they all couldn't be broken.
I will try your suggestions and let you know how it turns out. I would love to have a solution to this problem I have been battling for months.
Thanks,
Tony
Tony Weil
I tried the suggestions from kni and had some success. See the post at:
PS: I don't know the proper etiquette where to post my reply as this issue has now split into two threads.
Tony
