Hardware support => Low Power Techniques => Topic started by: ulli on September 13, 2015, 01:24:44 PM
Title: ListenMode settings to support ULP
Post by: ulli on September 13, 2015, 01:24:44 PM
I checked your ListenMode extension in your library and I do not understand why you
 * have a delay in your burst "delayMicroseconds( 5000 );"....not really a burst. It just sends one message every 5 ms.
    Does the 5ms delay does not cause transmission problems? I always try to send a burst with a minimum of transmission delays, to create a continues burst.
 * turn of the encryption. Do you see any disadvantages in the ListenMode by using encryption?
Title: Re: ListenMode settings to support ULP
Post by: joelucid on September 13, 2015, 04:18:03 PM
Hey Ulli, I think that part of the code originates from me so here are my comments:
It really is a continuous burst because the radio never leaves TX. What happens is the radio sends preamble while nothing else is sent. A problem with that setup is that packagesent gets triggered immediately for every packet after the first. Therefore you need to hand tune a delay (that's the delayMicroseconds). Finally encryption does not work when TX is kept on.
On the upside you get a burst that really does not include s gap - so great for listen more.
Post by: WhiteHare on September 14, 2015, 03:33:22 AM
FWIW, I appear to be hitting a 1ms Rx window 100% of the time while in Listen Mode by having the transmitter simply call sendFrame in a tight loop.  That results in a Tx cycle that's ~1.2ms long, with the Tx active for ~750uSec of each cycle.
Post by: joelucid on September 14, 2015, 04:12:38 AM
Sure - but I like to use RX windows 1/4 to 1/3rd of a ms. You are guilty of energy waste :)
Post by: WhiteHare on September 14, 2015, 11:41:00 AM
No doubt yours is a better way.  As a lesser milestone, though, I'm happy it works at all, especially because the underlying default RFM69 library code does appear to be using the sync word....I think.  I'll need to review it again to double check.  When you encountered the "bug", was it an intermittent thing, or did it happen every time?  i.e. Do you remember if there was there any pattern to it?
Post by: joelucid on September 14, 2015, 12:41:01 PM
It happened every time a radio in listen mode with address filtering on would receive a burst addressed to another node. In that case the radio got stuck in receive until the burst was over - regardless of timeout2.
Post by: WhiteHare on September 15, 2015, 12:25:31 AM
How long after the end of the burst was it that the radio got unstuck and returned to listen-mode?
Post by: joelucid on September 15, 2015, 03:13:12 AM
I didn't have a scope then, so I can only offer a roundabout estimate: the radio got unstuck immediately when the burst ended. That's why I think there's a chance that your non-burst method might not trigger the bug. However the bug is not a big issue since you can just disable packet filtering at the radio and reject the packet at the 328p.
Post by: WhiteHare on September 15, 2015, 07:52:00 AM
That's what I'm hoping.  If it does trigger it, then it sounds like I can dial-in a bigger gap between Tx's until it doesn't.  Adding gap is easy.  Getting smaller and smaller gaps, as you have already managed to do, is more challenging.
In any case, it would be interesting to know what the minimum gap size would have to be.  It sounds as though there is at least some gap already, though very small.  Have you or Tom measured what it currently is?
Post by: TomWS on September 15, 2015, 11:57:33 AM
I haven't but, unfortunately, I've put away my scope for a couple of weeks.  I probably wouldn't get around to measuring this until the middle of October. Sorry,
Post by: ulli on September 15, 2015, 12:47:24 PM
Some very good points :)
I use the the "Unlimited Length Packet Format" to create a continues burst. Therefore you are right and a encryption would not work with that TX mode. But this also applies with the CRC and data whitening/manchester function, don't it?
Additionally, I think that it is not necessary to hand tune the delay, if you use the following function to check the transmission/FIFO status during your burst?
Code: [Select]
while ((readReg(REG_IRQFLAGS2) & RF_IRQFLAGS2_FIFOLEVEL) != 0x00); // Wait till Threshold is not exceeded / Does not work in Sleep_Mode!
Regarding the so called "bug" in ListenMode. I guess the Module keeps receiving during your burst because it is comparing the incoming data with the sync and address filtering pattern till it hopefully matches. After the timeout it maybe gets immediately triggered again due to the high RSSI value and goes into RX Mode?
What do you think?
Post by: joelucid on September 15, 2015, 02:15:38 PM
Ulli,
Whitening and CrC work if the package size is under 255 bytes. But encryption generally only works if the radio is in mode standard when you fill the fifo and switch into tx afterwards. The datasheet can be read to support these experimental facts.
I like the fifolevel idea. I have to try that. If it works it would really help because hand tuned delays are obviously ugly.
Rg the timeout: yeah whitehare and I had already discussed that. But an interesting fact is that noise does not trigger this behavior. so there seems to be something special about seeing a real packet that doesn't match the address. Maybe in that case the radio stays in receive until RSSI drops at least once. In any case the workaround I described works well.
According to the spec the receiver is automatically switched off when timeout2 hits, so I think we can use bug without the quotes.
Post by: joelucid on September 15, 2015, 02:23:22 PM
Nope. My code does not produce a gap at all. Why don't you just use the workaround?
Post by: ulli on September 15, 2015, 03:15:22 PM
If you are right that the CRC works for "unlimited package length" (I could not find it in the doc) it can not be received right by our ListenMode Node, because the CRC is calculated over the complete burst message?
If we send a burst with a length of RX/Idle Time we should always have payloads >255bytes, don't we?
Just to be sure we talk about the same thing, in the following my TX code for "unlimited package length"
Code: [Select]
	for(uint16_t e=0; e<=lDataStruct->XDATA_Repeats; e++) {
mySpi.xferBegin(RF69_Config.spi_id);
mySpi.xfer_byte(REG_FIFO | 0x80); //set FIFO to TX Modus
//Data to RFM FIFO
for (byte i = 0; i < bufferSize; i++)  {
  mySpi.xfer_byte(lDataStruct->DATA[i]);
mySpi.xferEnd(RF69_Config.spi_id);
//TX control
if(!e) setMode(RF69_MODE_TX); //first push data while rfm69 is in standby
Post by: ulli on September 15, 2015, 03:19:16 PM
To have no gap is very important for the canSend() function of the ListenMode Node. Because if there is a gap in the burst I loose some ACK messages of the ListenMode Node, because the canSend() function detects that the burst is over and sends the ACK message to early.
Post by: WhiteHare on September 16, 2015, 04:48:57 PM
Strangely, it turns out the default for the RFM69 library is to have address filtering turned off.  Not sure why that would be.  If I turn it on, Listen-Mode continues to work just fine with address filtering on, regardless of whether packets are sent to the receiver node's address or not.   If I send a long string of packets (the 1.2ms cycle I described above), but to a different address, the receiving node continues with business as usual in Listen-Mode while  address filtering is turned on.  It did not go into a sustained Rx mode.  i.e. it did not encounter the bug.  So, just FYI, in case anyone is curious.
Post by: joelucid on September 20, 2015, 01:58:00 AM
Code: [Select]
Ulli, it works! Well actually not exactly your version, but this:
Code: [Select]
while ((readReg(REG_IRQFLAGS2) & RF_IRQFLAGS2_FIFONOTEMPTY) != 0x00);
You officially receive Joe's Listen Mode Medal  :). I can now send 5577 packets using 200kbaud during my 2900s burst period or 0.5ms per packet. I previously had the manual delay at 2ms. Once every 120seconds I poll my nodes for updates using listen mode. On average I will miss about half an packet delay - so I get a saving of 1ms / 120s * 16mA = 133 nA. Not huge but nonetheless.
I think the real benefit is that one can now send arbitrarily long packets without had massaging the code.
Thank you.
Joe
Post by: ulli on September 20, 2015, 09:40:34 AM
Did you set the RF_FIFOTHRESH_VALUE? My setup is as the following:
Code: [Select]
{ REG_FIFOTHRESH, RF_FIFOTHRESH_TXSTART_FIFONOTEMPTY | RF_FIFOTHRESH_VALUE }
RF_FIFOTHRESH_VALUE=0x0F
I do not understand how your code should work?
Code: [Select]
Therefore your while loop waits till the FIFO is empty. That must not happen in unlimited package mode.
You have to fill the FIFO during transmission and prevent it to be  empty or full.
Post by: joelucid on September 20, 2015, 11:16:06 AM
No, I don't use unlimited length packets. I use a non-interrupted burst of very short packets. So for me FIFO empty is exactly the right condition. If you use a huge packet how can your listening client pick up the beginning of one?
Post by: ulli on September 20, 2015, 01:46:26 PM
The client detects the preamble and sync words, like your client does.
Post by: WhiteHare on September 20, 2015, 01:49:32 PM
Are the two ways of doing it functionally equivalent?
Post by: ulli on September 20, 2015, 01:52:58 PM
Basically it sends the same message. I just want this unlimited package length method because I can be sure that there is no gap between the two message frames.
I had some issues with separated messages that the client detects the end of a burst within the canSend function to early and therefore I missed the client ACK several times.
Post by: ulli on September 20, 2015, 03:08:10 PM
Joe, would you post your send function? I would like to compare our to ways...
Post by: joelucid on September 20, 2015, 04:13:30 PM
Absolutely. Here you go...
Post by: joelucid on September 20, 2015, 04:19:03 PM
With coin cells canSend and even acks are death. When my clients receive a burst they powerDown until it's over and then send their update to the server. For me the need for a continuous burst is driven by the requirement for clients to always receive a packet during a burst no matter how short the RX period. You don't want the RX period to happen during a gap between two TX periods.
Post by: TomWS on September 20, 2015, 11:03:39 PM
I second Joe's nomination!  One of my Tiny TH Motes was a very poor 'listener' for some reason, randomly failing to respond to a wakeup burst about 30-40% of the time.  However, I made the change Joe mentioned above and it hasn't failed since (about 12 1/2 hours now).  I'll be updating my library in the next couple of days.
UPDATE: 2 misses out of 163, not good enough, but still a significant improvement from 1 out of 3!  I still have to dig into why this particular mote is weak.
UPDATE 9/23/15: Turns out there were NO errors after making this change.  See post https://lowpowerlab.com/forum/index.php/topic,1307.msg8979.html#msg8979
Post by: ulli on September 21, 2015, 01:11:05 PM
Hi ListenGuy`s, :)
I did some additional tests (also with Joes code) and spend some more time thinking about bursts....
Now I come back with a question which were not be answered by the datasheet :(
What is the trigger of the RFM module to send a new package and therefore the module adds the preamble, syncwords and does the calculations for the CRC and does datawhitening?
  * when I set the mode to RF69_MODE_TX coming from a other mode?
  * when the FIFO is empty and new data will be written to the empty FIFO?
  * when the SPI CS pin changes? (select, unselect)
I additionally found an issue in correlation with setting a small as possible REG_RSSITHRESH value to reduce phantom wake ups in ListenMode.
(I think that was the problem why my client did just run 2 month on 2xAA batteries)
I reduced the threshold till -80 and still get a good detection but the canSend function stops working well.
With low rssi thresholds the module can not longer detect when a burst is over.
--> Workaround: I do set the RSSIThreshold to his maximum when ever the CanSend function is running.
I would be thankful for further hints or your feedback.
PS.: With Joe`s code and the workaround it looks like I can transmit nearly 100% of packages to the client which is in ListenMode and get a ACK in <10ms after a burst.
Post by: TomWS on September 21, 2015, 02:04:30 PM
Keep it up, ulli and you might have your medal taken away from you  :-\
Why on earth would you want to try to get an ACK to a burst transmission?  That is so fraught with problems I can't even imagine them all!   If your sender needs an 'acknowledge' (notice the lower case) then each of the receivers can send ANY kind of Packet it wants AFTER the dust has settled on the burst and the network has quiesced.  What's wrong with this approach?
Post by: joelucid on September 21, 2015, 04:58:15 PM
Hi Ulli,
From the data sheet:
The transmission of packet data is initiated by the Packet Handler only if the module is in Tx mode and the transmission condition defined by TxStartCondition is fulfilled. If transmission condition is not fulfilled then the packet handler transmits a preamble sequence until the condition is met. This happens only if the preamble length /= 0, otherwise it transmits a zero or one until the condition is met to transmit the packet data.
I think we have the txstartcondition fifonotempty set. So if you fill the FIFO and the switch to TX transmission will get initiated. Also if you keep the radio in TX transmission will continue as soon as you start writing to the FIFO again. In between preamble will be sent.
Rg Rssithresh: I use Felix settings during normal operation. When I receive using my listener class I reprogram the radio to use a less sensitive threshold. After using listen more I reinitislize the radio, reestablishing Felix settings.
Like Tom said I wouldn't recommend acks. Just have the nodes send back a packet after the burst is done.
Post by: ulli on September 22, 2015, 03:34:41 PM
Hi joe,
Thanks for your hints!
Ok, therefore in the case of keeping the radio in TX transmission the separation of two packets will be defined by a Fifo empty condition.
As soon as I write to the empty Fifo the radio is starting to send the preamble, syncwords, the new Fifo filled payload an calculates on the fly the CRC?
Is that correct?
Based on that facts your proposal "while ((readReg(REG_IRQFLAGS2) & RF_IRQFLAGS2_FIFONOTEMPTY) != 0x00); " make sense!
All right you are doing something similar!
Of course, I know that waiting in RX till a burst is over is waisting energy!
I will include a byte in the payload to give the client the information for the sleeping period when the burst is over later on...(something similar like you did in your code )
Post by: TomWS on September 23, 2015, 08:47:01 AM
Updating on the 'errors' I had cited in my post https://lowpowerlab.com/forum/index.php/topic,1307.msg8918.html#msg8918, it turns out that I was misreading the data and the Tiny TH Mote has had NO errors (out of 477 samples) since making the change to remove the delay in the burst transmission loop.   That is compared to the approximately 35% error rate from before the change.
Apparently my Gateway has been acting up for another reason, but that was hidden by my hardware Watchdog!  Sigh, what a tangled web we weave...
The updated RFM69_ATC library has been posted to the github: https://github.com/TomWS1/RFM69_ATC/tree/ListenModeExtensions
Post by: ulli on September 23, 2015, 11:44:23 AM
You are welcome Tom  :P ;)
