Just got a few IoT door sensors that I really like, but I don't like how everything goes through a cloud service that could dissapear.
So I've been putting a lot of time lately into an alternate library, which I'm calling SG1, trying to make things scalable to large numbers of cheap devices.
The biggest change is that I'm using software encryption. Packets have timestamps which also serve as IVs for the crypto, and when a node has an incorrect time, the other nodes use bit flags in the header to decide if their local clocks are better, and if so they inform the wrong device(Using the same wrong IV as a challenge response).
For everything I'm doing, I believe it's secure enough, but clocks start out with 7 byte random negative numbers, and clocks can go backwards, so there's a possibility for very occasionally accidentally reusing an IV, even though the resolution is 256us.
I'm also only using 64 bit MACs, so I'm not sure if this is "secure enough" for most people's needs.
The other thing I've done is get rid of addresses. You don't send to a specific node, you send to a "channel key", and anyone set to that key gets it. We never explicitly send the channel, just 3 bytes of the hashed key, as a "hint". Collisions don't really matter, you just ignore anything you can't decrypt.
I'm also not using listen mode for the low power, because I don't like how much data you have to send and the unpredictable chance of receiving things.
Instead, I have "short beacon messages", which contain a 3 byte "private Hint sequence" that constantly changes. When we send one of these, we listen for about 100ms for a response.
If there's no response, or the response is just another hint sequence message, we note the RSSI for the auto TX power, and go back to sleep. I may change this response to be the hash of the hint, so you can't fake the presence of the other device just by repeating the message.
If the response is the channel's "wake sequence", we stay away for a few seconds, resetting the timer whenever we get a real message.
All messages can use full Golay error correction (which doubles the packet size, so we only use it when the power level is high).
Unfortunately this means sending a packet and listening for 100ms on a regular basis(I think you only need about 25ms, but serial ports have more latency than that, so you'd need hardware assistance to have a PV gateway respond that fast), so I'm also looking into designing some cheap LTO based energy harvesting boards, since most things can run at 1.8v these days.
The next thing I'm planning to work on is automatic pairing mode. I want to have a predefined pairing frequency, and let add a pairingMode() function plus a pairWithRemote() function that lets you set everything up automatically, Bluetooth style, and unique device UUIDs that can get discovered in the process.
Ideally, I would *really* like to see a fully open standard that's as easy to use as typical consumer equipment, to end some of this IoT waste and make the technology accessible to everyone without fragmented piles of different expensive hardware.
Anyway, here's what I have so far, Although it's all alpha and subject to change, it does seem to work pretty well on Moteinos.
What do you guys think? Should I be adding a few extra bytes of IV to get rid of the(possibly one-in-a-millon security issues?)
Should I limit the beacon recieve window to 25ms, and just rely on smarter PC interfaces that can respond without waiting for the PC?
Thanks guys!
https://github.com/EternityForest/SG1
