Hardware support => General topics => Topic started by: Uncle Buzz on December 05, 2018, 10:29:18 AM
Title: USB connector for serial communication ?
Post by: Uncle Buzz on December 05, 2018, 10:29:18 AM
I want to use a µUSB connector to supply power to recharge a battery on a node, but without including an USB to serial converter IC like those from FTDI. But I would like to use an external USB to serial converter without exposing another connector for programming or debugging, so I would like to use the µUSB connector to connect TX and RX pin of an ATMEGA328P or 1284P.
I wonder what will happen to the ATMEGA if someone plugs a real USB to this connector, TX and RX pin will be connected to D+ and D- of USB... What if my node is unpowered and there're some 5V signals on TX and RX pins ? What if my node has some periphericals like the radio RFM69 running at 3.6V max if there're some 5V signals on TX and RX pins ?
Are 2 P-mosfets acting as a shift leveler sufficient to protect the ATMEGA and other parts?
Title: Re: USB connector for serial communication ?
Post by: Felix on December 05, 2018, 11:08:57 AM
That's quite creative and unconventional, but I think it should work with a few precautions.
Worst case is of course someone plugging real USB into it.
If the TX is an OUTPUT, and D+/- tries to also output into it, there will be current drain problems - so I would add a resistor there at the least to limit any damage to either side. Also since I havent tried or over analyzed this, take it with a grain of salt.
So the TX/RX would get 5V, so at the very least you'd need logic level conversion to bring that down to the AVR's VDD level. Hence if USB does meet serial TX/RX, there is no damage to the AVR.
I think 2 mosfets should do the job as you mentioned, but I would put this on paper and see if ohms law raises any red flags based on the possible scenarios.
Post by: Uncle Buzz on December 06, 2018, 03:36:39 AM
I was thinking about Perky's link on the thread about the leakage current inside the FTDI in the off state: https://www.nxp.com/docs/en/application-note/AN10441.pdf
It's not with P-channel mosfet as I said but with N-channel.
If I'm not mistaken, it would protect against USB 5V in all possible cases, right?
Post by: Felix on December 06, 2018, 09:52:01 AM
Quote from: Uncle Buzz on December 05, 2018, 10:29:18 AM
I thought you wanted to do voltage level shifting?
Post by: Uncle Buzz on December 06, 2018, 02:22:14 PM
Not really, level shifting is not the main goal, I just want to use an external FTDI but using the µUSB connector instead of some dedicated pins.
But, since it's a µUSB connector, it's quite certain than a real USB will be plugged at a moment, so I want to be protected against this scenario. So I need to block 5V signals on D+ and D- from a real USB connection to go through my ATMEGA and burns some components.
The link posted by Perky is about level shifting by using a Nchannel mosfet, and to my mind it's sufficient to protect my node :
So level shifting is not what I need, but if it works as low than 0V on one side, it's sufficient, and level shifting could be useful with a 5V FTDI.
Nchannel mosfet used like the NXP's note acts as a level shifter, and works even with 0V.
If anyone sees anything wrong with this solution, please show me where I'm wrong!
