Strange behavior with #define constant
Started by Uncle Buzz, November 29, 2019, 08:44:24 AM
Uncle Buzz
I define some constants with #define to reuse many times in my code.
When constant are use directly like pin definition, there is no problem, but if I compute some things with them, results are not what I expected...
Could someone tell me why this occurs? I tried to use some cast but same results...
I put a simple example sketch below, and the result I obtained...
#include "arduino.h"
#ifdef __AVR_ATmega1284P__
#else
#endif
#define SERIAL_BAUD   115200
#define FLASHSECTOR 1UL<<12 // 4096
#define FLASHPAGE 256
void setup() {
	Serial.begin(SERIAL_BAUD);
	pinMode(PIN, OUTPUT);
	digitalWrite(PIN,HIGH);
	delay(DELAY_MS);
	digitalWrite(PIN,LOW);
long lastPeriod = 0;
void loop()
	Serial.print("FLASHSECTOR = ");Serial.println(FLASHSECTOR);
	Serial.print("sizeof(FLASHSECTOR) = ");Serial.println(sizeof(FLASHSECTOR));
	Serial.print("18 % FLASHSECTOR = ");Serial.println(18 % FLASHSECTOR);
	Serial.print("18 % (1UL<<12) = ");Serial.println(18 % (1UL<<12));
	Serial.print("FLASHSECTOR * (18 % FLASHSECTOR) = ");Serial.println(FLASHSECTOR * (18 % FLASHSECTOR));
	Serial.print("(1UL<<12) * (18 % (1UL<<12)) = ");Serial.println((1UL<<12) * (18 % (1UL<<12)));
	Serial.print("0 % FLASHSECTOR = ");Serial.println(0 % FLASHSECTOR);
	Serial.print("FLASHSECTOR * (0 % FLASHSECTOR) = ");Serial.println(FLASHSECTOR * (0 % FLASHSECTOR));
	Serial.print("FLASHSECTOR * (0 / FLASHSECTOR) = ");Serial.println(FLASHSECTOR * (0 / FLASHSECTOR));
	Serial.println();
	Serial.print("FLASHPAGE = ");Serial.println(FLASHPAGE);
	Serial.print("sizeof(FLASHPAGE) = ");Serial.println(sizeof(FLASHPAGE));
	Serial.print("18 % FLASHPAGE = ");Serial.println(18 % FLASHPAGE);
	Serial.print("18 % 256 = ");Serial.println(18 % 256);
	Serial.print("FLASHPAGE * (18 % FLASHPAGE) = ");Serial.println(FLASHSECTOR * (18 % FLASHPAGE));
	Serial.print("256 * (18 % 256) = ");Serial.println(256 * (18 % 256));
	Serial.print("0 % FLASHPAGE = ");Serial.println(0 % FLASHPAGE);
	Serial.print("0 % 256 = ");Serial.println(0 % 256);
	Serial.print("FLASHPAGE * (0 % FLASHPAGE) = ");Serial.println(FLASHSECTOR * (0 % FLASHPAGE));
	Serial.print("FLASHPAGE * (0 / FLASHPAGE) = ");Serial.println(FLASHPAGE * (0 / FLASHPAGE));
	Serial.println();
	Serial.println();
	Serial.flush();
	delay(1000);
	Blink(LED,3);
result :
QuoteFLASHSECTOR = 4096
sizeof(FLASHSECTOR) = 4
18 % FLASHSECTOR = 0
18 % (1UL<<12) = 18
FLASHSECTOR * (18 % FLASHSECTOR) = 1
(1UL<<12) * (18 % (1UL<<12)) = 73728
0 % FLASHSECTOR = 0
FLASHSECTOR * (0 % FLASHSECTOR) = 1
FLASHSECTOR * (0 / FLASHSECTOR) = 1
FLASHPAGE = 256
sizeof(FLASHPAGE) = 2
18 % FLASHPAGE = 18
18 % 256 = 18
FLASHPAGE * (18 % FLASHPAGE) = 0
256 * (18 % 256) = 4608
0 % FLASHPAGE = 0
0 % 256 = 0
FLASHPAGE * (0 % FLASHPAGE) = 1
FLASHPAGE * (0 / FLASHPAGE) = 0
It's because of operator precedence.
Modulo (%) is greater than bit shifting (<<) so the compiler result is correct.
The preprocessor simply replaces your define expressions where they are included in your code.
Uncle Buzz
I thought preprocessor replace with the computed value of 4096 instead of keeping 1<<12, but it makes sense...
And some wrong copy/paste did the rest...
Thank you !
