Mailbox Notifier Upgrade #3
As I explained in my lipoly+freezing=failure post, I ran into a snag with the brand new Lithium Polymer battery operated MotionMote that serves as my mailbox notifier. It discharges quickly after being exposed to the cold for a while, it seems like below 30F it goes downhill and then falls off the cliff and dies around 24F (-4C). After a recharge the cycle repeats, every time dying a little faster which means cold damages them permanently. So being tired of this nonsense I wanted to give alkalines a try and also wanted to add a WeatherShield to the mailbox, if it’s out there why not report temperature, humidity and pressure as well in addition to telling me when the mail is delivered.
UPDATE: the LiPoly batteries are still working great above freezing and will provide a compact and longer lasting charge than a 3xAAA pack. In the spring time I switch to a LiPoly because it lasts longer and I can charge it directly from the onboard USB of the MotionMote PCB. In the winter I go back to alkalines because they survive in the deep freeze.
The first step was to solder the weather shield on top of the Moteino, only 7 pins are soldered after being raised a little: GND, VIN, 3.3, A7, A5, A4, A3. The bottom of the WeatherShield was insulated with a piece of electrical tape to avoid any shorts.
Then I added the new battery – a 3xAAA holder with older batteries. I needed 3x of them to get above 4V so there’s some head room for the voltage regulator on the Moteino and the PIR sensor which was modified to allow running into much lower voltages. I could have soldered the battery holder wires directly to the MotionMote PCB but I had some spare female JST connectors and I added that to make it easy to remove later if needed. I took the measurements to lasercut another box that will fit this.
With the help of previous box designs I was able to get the dimensions and hole alignments right the first try. The box blueprint is published here for those that might find it useful. Here’s everything after test fitting:
Velcro goes on the back and the Moteino antenna protrudes from a hole in the box through a short cut in the velcro. The wire antenna also goes out the mailbox through a tiny hole. The slots in the side allow air to go in for better humidity readings.
After some minimal coding, the mailbox notifier sketch is altered to do the WeatherShield readings. The new sketch is published in the same repo. The new mailbox is now smarter and it gives all the following readings:
LO:4h1m BAT:4.36v F:3475 H:37 P:29.32
where LO is last open elapsed time,  F is fahrenheit in hundreds (divide by 100), H is humidity in %, and P is atmospheric pressure in inHg. It’s also running happy after being buried in the last winter storm. In the morning when the sun hits the mailbox directly the temperature can rise 20-30 degrees above the real temperature, but otherwise throughout the day it’s pretty stable and comparable to WeatherUnderground, when it’s overcast it’s often within 1 degree of WU but I am aware there are multiple factors that can influence a temperature reading in such a location. Humidity and pressure readings are also very stable and rise very deterministically.
3 thoughts on “Mailbox Notifier Upgrade #3”
  1. Have you ever thought about developing an energy harvester power supply based upon a solar cell and supercap or thin film battery? Those would solve the temperature issues as well as make them pretty much service free.
    http://www.digikey.com/en/articles/techzone/2012/nov/managing-the-energy-and-lifetimes-of-thin-film-batteries
    I live in Phoenix, AZ and the summer temps tend to kill a LiPO battery after a single season. I’m going to try to make a supercap energy harvester and see how that functions. I guess a thin film battery might be better if one has longer stretches of cloudy days to provide power for.
  2. So its taking the cold ok. Have you thought about adding solar to charge the unit?
    For the commenter Michael, have you built such a device? Do you have a twitter or blog?
    • Yes, but never considered it a good idea. Makes the mailbox stand out and the charging electronics are more complex/expensive. Batteries are a good compromise, alkalines during winter freeze and LiPo the rest of the year are working great.
Comments are closed.
