New Dipole Antenna Review & How-To
I’m pleased to introduce a new version of the PCB Dipole Antenna, a significant upgrade from the previous version. This has a nice VSWR of almost 1.0 at both 868Mhz (at default 78mm length), and 915Mhz (trimmed at 73.5mm). It could be trimmed anywhere down to 2.4Ghz but it will be a best performer for the wideband LoRa and FSK radios in the sub Ghz ranges. Be sure to check out the dipole section in the RF-Best-Practices Guide for more theory on the dipole antenna.
4 thoughts on “New Dipole Antenna Review & How-To”
  1. Hi Felix,
    antennas looks great, but how do you convert balanced signal (what dipol is) to unbalanced signal (SMA)? There have to be some losses.
    • Yes there will be some loss but you may use a balun if you want to minimize those losses. In practice this dipole will perform better than the unbalanced monopole.
Leave a Reply
