The WirelessProgramming GUI is now at v1.6. You can find and download it here. Please note it is no longer part of the RFM69 library, but has been moved into its own WirelessProgramming repository. Here are some changes:
- protocol improved to support variable HEX record length
- various other minor bugs fixed
- removed the logging delay in v1.5 since it was causing some glitching
Since v1.5 (release notes here) you may know that this OTA GUI can also invoke the OTA.py script which is included with it. This way you may customize the OTA.py script to your own needs, the windows GUI uses the same algorithm. The GUI includes the IronPython runtime and libraries required to invoke this python script right from the app. You may of course simply use the OTA.py script independently if you’re so inclined.
I spent a few days doing testing and I would like to invite Moteino users to try this new version and report any bugs via the contact form.
For those interested in future releases – last year I developed a new OTA algorithm which cuts the upload time dramatically. I mentioned this briefly in the forum but I got distracted in many other directions and it’s not finalized. It is more complex and needs a lot of testing and fine tweaking. It was originally intended for transferring small files via non-wifi subGhz transceivers (RFM69) and would need porting and adjustments for OTA purposes. I would like to hear feedback and see the level of interest about wireless programming of Moteinos (aka OTA programming). Feel free to drop a line and share your experience so far and change requests.
