The Moteino Framework Gateway software stack was updated to V7 and new sources are available at their Github repo, and also a new debian-wheezy image with the changes is released (for the image link see the Gateway image page). This release addresses some bugs and adds some significant refactoring and moving of directories. Most importantly the gateway application is now residing in /home/pi/gateway along with the public www directory for ease and more consistency (previously in /home/pi/moteino). Here are the other changes that go with this:
- the www directory is moved from /var/www/default to /home/pi/gateway/www
- the .htpasswd file and ssl certificate files are now in /home/pi/gateway/data/secure
- the database files and log data are now kept in /home/pi/gateway/data/db
- nconf is used to manage the settings file (previously known as settings.js, it was using straight nodejs exports to import the settings) which is now named settings.json5 and is a JSON5 based (via json5 package) settings file which can be manually edited as well as maintained through the app (in a future release)
- there is a new package.json file which includes all the node dependencies. If you’re inclined to manually install the software stack, now all you have to do is cd /home/pi/gateway and npm install to get all these dependencies installed
- the nedb power-loss database purging bug is fixed with a new nedb 1.5 upgrade
- all server configuration files are updated to reflect the new paths
- other misc minor changes and optimizations
As usual, if you detect any bugs in this release please let me know asap. Enjoy!
