A few weeks went by since I blogged about the new Gateway interface. I managed to get the code ready and I posted the links on the dedicated gateway page where I prepared a guide to install the stack needed to support it (this will be improved). The code itself and sources are published at Github. There you will find the old interface sample I had posted a long time ago (in the OLD subdirectory, kept there for reference); the files are replaced with the new interface files.
There are 2 directories where you will need to copy files from here after you’ve completed the setup of your Pi from this guide (I may release a Pi image that has everything setup and ready to go). Please note: when you download stuff from Github you must use the Download Zip button in the repository rather than downloading individual files.
First there is the /var/www /default directory, you should copy these files there:
- the images subfolder
- the sounds subfolder
- index.php, graphHelper.js
Second there is the /home/pi/moteino directory, you should copy these files there:
Once the gateway starts running it will create the databases for you and start logging data as it comes in from your remote nodes through the gateway Moteino attached to your Pi’s serial port configured in the gateway.js script.
This post is not meant to replace the guide found at the lowpowerlab.com/gateway page. I will post further details there. I created a new forum for discussing this and other gateway related topics so please post your questions there.
