There is now a new revision of Moteino USB (R5). It has 27ohm resistors on the D+/D- lines and pulled up the RST line on the FT231XS chip which should help with any upload issues, see this forum post for more details.
Also the new FTDI Adapter (R2) fixes the same issue and also switches from FT232RL to FT231XS. The reason being the economics of using a chip that is not only cheaper while doing the same function, but also the one and only USB-serial converter I now use.
I assemble all these boards on a pick and place machine and having a reduced and more efficient BOM makes a big difference. The FT232RL came in a wide 24mm tape which occupied a separate 24mm feeder. Buying a full reel of those parts is an impossibility given the price, and partial reels require a leader to load into the feeder, an extra fee every time you buy anything less than a full reel. Plus, some of the leader tapes I buy from Digikey break off pretty easily and so it’s a pain to work with individual feeders and I’m trying to avoid leader tape whenever I can. The FT231XS come in tubes which makes it much easier to work with using the vibe feeder. The only downside is that I have to reload them more often (58 parts per tube).
Hey felix, not sure if you have seen the following kickstarter project but this looks neat for doing pcb protos..
https://www.kickstarter.com/projects/voltera/voltera-your-circuit-board-prototyping-machine/description
All the best,
X
Thanks, yes I was aware, there are many such KSes and types of all-in-one machines. I was never a fan of these and always thought they are hopeless and just expensive toys. There are too many things wrong with the concept to list here.
