2 thoughts on “MightyBoost available”
  1. Anyway to add solar panel to this? Solar panel to charge the battery and run the system during the day and use the battery at night.
    • This uses MCP73831 which expects constant current and voltage for charging. If you can meet that current with the solar panel then it should be OK, otherwise no.
Leave a Reply
