LowPowerLab Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Blog
Shop
Help
Search
Login
Register
LowPowerLab Forum
Hardware support
General topics
Using RFM69 with Arduino Nano
Print
Pages: [
1
Author
Topic: Using RFM69 with Arduino Nano (Read 13790 times)
Richelsdorfite
NewMember
on:
October 21, 2013, 03:39:10 PM »
Hi,
I want to use RFM69 module with an Arduino Nano V3.
As RFM69 levels seem to be 3V3 and the logic levels of the Nano are 5V, should I use an adapter level ?
Regards,
Michel
Logged
Richelsdorfite
NewMember
Re: Using RFM69 with Arduino Nano
Reply #1 on:
October 22, 2013, 03:50:16 AM »
Silly question = simple answer "Yes".
Logged
Administrator
Hero Member
Country:
Reply #2 on:
October 22, 2013, 08:11:49 AM »
The easy way out is to give it 3.3V power and use 10K/4.7K resistors for the data lines, except MISO which doesn't need it since it's input
FROM
the RFM69/RFM12B module.
Logged
Richelsdorfite
NewMember
Reply #3 on:
October 29, 2013, 04:21:06 PM »
Ok, I made a first try.
But the Nano don't like.
I connect the RFM69 to the Nano like:
First side:
NC is not connected.
NSS is an input for RFM69 so I use a voltage divider and connect to Nano328 D10
MOSI is an input for RFM69 so I use a voltage divider and connect to Nano328 D11
MISO is an otput for RFM69 so I
don't use
a voltage divider and connect to Nano328 D12
SCK is an input for RFM69 so I use a voltage divider and connect to Nano328 D13
GND is not directly connected to the Nano as it's connect to the other GND
Antenna to a 16,5 cm antenna as I use a 433MHz
GND is connected to Nano ground
Second side:
Reset is not connected .
DI00 is an input for RFM69 so I use a voltage divider and connect to Nano328
D12
D2
DI01&02&03&04&05 are not connected
3.3V is connected to Nano 3.3V
I use the Gateway sketch and the Node sketch, none of them work.
I presume that the wire length between the Nano and the RFM 69 should be minimized to prevent interference ?
When I connect the RFM69 power to the Nano 3V3, the Nano does not seem to hold the power demand and restarts.
Any idea :-)
Michel
Last Edit: October 30, 2013, 03:13:22 AM by Richelsdorfite
Logged
Richelsdorfite
NewMember
Reply #4 on:
October 29, 2013, 04:33:14 PM »
Arg!!!!!
DI00 seems to be an output !
Logged
Administrator
Hero Member
Country:
Reply #5 on:
October 29, 2013, 05:37:46 PM »
All the DIOs are outputs FROM the RFM69.
Oh and DIO0 is supposed to go to D2.
Logged
Richelsdorfite
NewMember
Reply #6 on:
October 30, 2013, 06:36:09 AM »
I think the 10k/4.7k voltage divider is not good for time constant.
I try and the output signal from the Nano which are similar with the signal from Moteino the first 5V and the second 3.3V and this voltage divider change the signal.
So I find
http://electronics.stackexchange.com/questions/21055/voltage-level-shifting
and try a voltage divider made with 2k/1k, the signal from D13 is not change only the level.
Logged
Richelsdorfite
NewMember
Reply #7 on:
October 30, 2013, 07:19:11 AM »
And................................
It's working good !
Logged
Administrator
Hero Member
Country:
Reply #8 on:
October 30, 2013, 08:21:02 AM »
Cool.
Just FYI - the 1k/2k will eat more power though.
Logged
Sirocco
NewMember
Reply #9 on:
March 01, 2014, 01:45:38 PM »
Hello people.
Richelsdorfite, could you use RFM69W with Nano with the wiring which you describe above ? And will it be right for the Mega and Uno also ? ?
Logged
Richelsdorfite
NewMember
Reply #10 on:
April 08, 2014, 03:05:23 PM »
Yes, of course.
But the purpose of my setup was to try not to use. So I have no feed back.
Logged
Print
Pages: [
1
LowPowerLab Forum
Hardware support
General topics
