The Wireless Programming GUI app that I introduced in an earlier post is now at version 1.2 (get exe here). It features the ability to bundle up to 3 HEX file lines per RF packet (instead of the default 1), which yields a significant transfer speed increase. Let’s just do the TL;DR first and gaze at the results of transferring a compiled sketch of 13,858 bytes:
- running with 1 line per packet (the same as before) yields 866 packets and ~43s OTA time:
- running with 3 lines per packet yields 290 packets and ~18s OTA time:
That’s an average 58% speed gain, not too bad!
By comparison, the same sketch uploaded directly via FTDI/serial takes about 13s, so much closer to that figure than before. I think a few other techniques could be used to squeeze yet more speed (increasing RF bitrate!) but that’s for another day.
Note that the same exact data is transferred, except in fewer longer packets. I had to make some changes to the WirelessHEX69 library to support these longer packets. Also I fixed some bugs that emerged during this development, see the github commit for all the changes.
To support the new GUI v1.2 speed increase you only need to update your WP programmer Moteino with a new version of the WirelessProgramming_gateway sketch (to refresh the WirelessHEX69 code) to make it support the faster WP speed (ie also update the WirelessHEX69 lib!). Everything else is completely backwards compatible, and you can use the new GUI v1.2 with an older WP programmer Moteino if need be (1 line per packet only), and also all old target nodes that are OTA/WP programmable are not affected at all and can be updated at the new speed. FWIW you can actually use 1 or 2 (not sure why you would) or 3 lines per packet (the new default going forward). Experiment and see what your own speed gains are! Please report any bugs or issues in this forum!
